V-tec at 5200?
Old Feb 14, 2008 | 08:14 AM
Oh1TypeS's Avatar
V-tec at 5200?
I've noticed that v-tec does not hit untill 5200rpms? From what I read its supposed to be 4800... I have an 01 type-s... Any ideas?
Old Feb 14, 2008 | 10:13 AM
spdy0001's Avatar
I now drive an accord....
The Type-S does engage at 4800, and the regular CL engages higher.
I assume you are just viewing the stock tach with a naked eye? This is a very inaccurate way to judge RPM. The stock tach's are not the most accurate devices.
Old Feb 14, 2008 | 11:29 AM
underst8's Avatar
140,000 miles young
I have been thinking about a cluster mod - specifically moving the speed to where the tach currently is, and custom fitting like an autometer tach where the speedo normally resides. Would be tight.
Old Feb 14, 2008 | 12:02 PM
typeR's Avatar
also like a shift the point at which it starts the process and completes is gonna be two different things
Old Feb 14, 2008 | 02:01 PM
mystikk's Avatar
failhard.
Maybe this is why I can hear VTEC start to scream at 5000 RPM instead of 4800? I've noticed this for quite a while, was wondering in the back of my mind all this time of that was abnormal or not ..
Old Feb 14, 2008 | 02:47 PM
gc86's Avatar
Advance
On my girlfriends 01 CL-P I hear VTEC crossover at around 4500.
Old Feb 14, 2008 | 03:03 PM
GreenMonster's Avatar
http://www.geocities.com/gamesmgr/chod/acura/#Engine2
Old Feb 14, 2008 | 04:45 PM
typeR's Avatar
Originally Posted by GreenMonster
think thats incorrect this is a quote from honda...
As the engine accelerates through 4400 rpm (4800 rpm on Type S), the intake rocker arms transition to actuation by high-lift, long-duration cam lobes designed to optimize high rpm
Old Feb 14, 2008 | 05:09 PM
gc86's Avatar
Advance
Yeah that guide is definitely wrong. The crossover point is defined and clear on the dyno and the street.
Old Feb 14, 2008 | 10:59 PM
NightRider's Avatar
SOLD
Yeah the Pees definitely engage VTEC at a lower RPM, correlating with their lower redline. When I had my VTEC Controller I took the car all the way to 7200, the "true" redline for the type s, and the VAFC read 6900 or 6999 (can't recall which) when the tach read 7200...The VAFC was hooked to the ECU so I would trust that more than the speedo, so our RPM's are off by at least 200 RPM. I even used to think my VTEC engaged around 5K as well until I got the VAFC lol
Maybe that documentation for the VTEC was a 1G J CL/TL or F22?
Old Feb 15, 2008 | 07:17 AM
Oh1TypeS's Avatar
I guess that explains it, thanks for the info.
Pham Alvan
Mar 16, 2016 09:17 AM
KB1Spec
Aug 20, 2008 11:31 AM
goturcode
Jun 26, 2007 11:10 AM
blo2ck
Feb 26, 2003 12:31 PM
johntypes
Nov 1, 2002 03:27 PM
