UR Pulley Install. Finally.
Old Nov 14, 2007 | 02:05 AM
GrandeInter10's Avatar
Si Vis Pacem, Para Bellum
This afternoon I received it, and by 5 it was installed. The difference isn't like night and day but it's noticeable. Revs a bit quicker and pulls harder. I like it. Good mod. And I probably never would've known about it if not for all you guys, so thanks guys!
Old Nov 14, 2007 | 04:16 AM
Accord_V6_400m's Avatar
4drs just wanna have fun!
So how was the install for you, find anything that worked best for you?
Old Nov 14, 2007 | 06:39 AM
03silvertypeS's Avatar
congrats...i've had my pulley set for like a year now and still haven't put them in (damn i suck)
Old Nov 14, 2007 | 10:50 AM
My best friend owns a shop, so he installed it I installed my own headers tho! haha
Old Nov 14, 2007 | 11:51 AM
LIPPSTUH's Avatar
Unregistered user
did u get underdrive? hey save my stock exhaust for me, i'm going to pick it up on tuesday when i come back down =D
Old Nov 14, 2007 | 06:14 PM
Dude you shoulda told walter when you were there. they might still be in the back but not a guarantee. i'll pm you later, after i go down there to look at some rims.
Oh and yeah, it's the underdrive.
Old Nov 14, 2007 | 06:51 PM
LIPPSTUH's Avatar
Unregistered user
ok let me know, i did tell him i'd pick them up but onsunday but my schedual was packed... worked on my car all day b/c i go to school in irvine..
i'm coming down tuesday for dinner with family and a supposedly huge meet. u down?
Old Nov 14, 2007 | 08:34 PM
HondaVtec21's Avatar
Do you experience a squeeking noise when your AC or Heat is on? Ever since I installed the UR 3-Piece Pulley Set, I get this annoying loud squeeking noise whenever my fan kicks upp!! Anyone know how I can reslove this???
Old Nov 14, 2007 | 08:40 PM
SPoolinspOON's Avatar
OG 3.x^7 rawr
check the tension of the belts. Maybe spray a bit of belt dressing?
TCM 01 CL-S's Avatar
Uses turn signals in my
Nope, but I only have the crank pulley. You could always hit it up with belt dressing and see what happens.
Old Nov 14, 2007 | 10:17 PM
m733l's Avatar
hey where is your friends shop and how much will he charge me? i bought the 3 pc stock size and was only able to get the power steering and alt. on there. so all i need is just the crank (stock size) to be installed.
Old Nov 14, 2007 | 10:28 PM
Dirty Type-S's Avatar
B A N N E D
crank is easy as long as u have a 3/4" impact gun. hahah i cal her big bertha.. its a huge gun but it pops off the crank liek nothing... its almost impossible to get it off with a 1/2 in gun/
Old Nov 14, 2007 | 10:53 PM
m733l's Avatar
so all i need is for you to ship ur impact gun to me?
Old Nov 14, 2007 | 11:04 PM
Haha honestly he'd probably charge you too much. if you're mechanically inclined why don't you rent an impact gun and a compressor? it'd probly be cheaper to be honest. but if you want i can give you the address and most likely it'd be around 90. give or take.
Old Nov 14, 2007 | 11:06 PM
For sure, if I don't work. And yeah, they're still there.
Old Nov 15, 2007 | 04:18 AM
Yeah I have some squealing sounds too seems to get louder as I rev higher but only to a certain extent upon which my motor and exhaust just overtake it. It makes some sort of bird call noise, doesn't really bother me too much since some people think im supercharged as a result, yeah I know lame but some people just don't know better. I think its the belt tension I had to get a 4060460 per part catalog but when i called Goodyear about it being to tight they told me that they updated their info and they now recomend a 4060465 for the serpentine belt.
Old Nov 15, 2007 | 01:41 PM
I got the Gates belts and it sounds fine. What is making noise is the headers. And it's getting annoying. We replaced the flex pipe and it got worse. So now my car sounds like a vacuum when i accelerate until VTEC hits.
Old Nov 15, 2007 | 07:37 PM
m733l's Avatar
okay i give up. whats his number? i need to get this done .....now!!!
Old Nov 16, 2007 | 12:49 AM
If your in So Cal I can do it for you for like $75, the biggest hassle is just getting the belts on, at least for me, otherwise it would probably be the crank pulley for someone else.
Old Nov 16, 2007 | 01:05 AM
I'd say that's a better deal ^ but if you want to go to my friends shop the number is (626)-797-1194. it's in pasadena. 134 freeway, exit fair oaks ave(north) and it's on the corner of howard and fair oaks. i can probably have him bring down the price, but no promises. good luck with whatever you decide man! you'll feel the difference!
Old Nov 16, 2007 | 01:37 AM
m733l's Avatar
thanks for the info. is there a contact person? what time in the morning will he be available?
Old Nov 16, 2007 | 01:40 AM
m733l's Avatar
do you have a big bertha? can i borrow it? really all i need is the 3/4 impact gun (in theory)...but can't justify buying one when i can get it installed for much less.
ask for either walter or edgar. tell them eric referred you. they open at 8 am and one of them will be there all day.
Old Nov 16, 2007 | 01:45 AM
m733l's Avatar
hopefully they can get it done in the morn. how long did it take him?
Old Nov 16, 2007 | 01:48 AM
About 2 hours. But they were busy so they were doing it on and off, and me being a friend I didn't mind. But it shouldn't take that long for you if you get there early. They don't get too much work until about 9 or 9:30.
Old Nov 16, 2007 | 04:38 AM
Nope, managed to get it done with a lug nut wrench and a long pipe
Old Nov 16, 2007 | 09:59 AM
m733l's Avatar
well, i have already snapped a couple of extensions. for some reason the bolt does not want to come off. like its welded on or something.
Old Nov 16, 2007 | 05:20 PM
Yeah, I know the feeling, if you use anything with joints or extensions it gets worse, when I use the lug nut wrench and a pipe everything is pretty mucha one piece unit, the two together reall ydont have much slack at all which is great because your not risking the chance of losing all that torque and beak some tools etc.
Old Nov 16, 2007 | 07:58 PM
m733l's Avatar
thanks eric. took it to them this morn and got it handled. cool group of guys there. probably gonna have them do a custom 2.5 b-pipe for me this weekend. as for the update on the 3pc pulley stock size-i don't really notice anything substantial yet... but i also haven't floored it yet either. i don't know, maybe it's because it's stock size but from what i understand it should produce the same hp minus 1 or 2 horses. anyway thanks again for the connection.
Old Nov 16, 2007 | 09:15 PM
LiquidCLs6's Avatar
does the pulley come with a step by step installation booklet or something? i've searched for a DIY on here but keep getting tons of pulley threads with no step by step instructions, if someone can point me in the right direction that would be great. thanks!
Old Nov 16, 2007 | 10:48 PM
fsttyms1's Avatar
here is a little tool a TL member devised that worked for him
https://acurazine.com/forums/showthr...ght=crank+bolt
Old Nov 17, 2007 | 05:32 AM
no problem man. glad everything went smooth. and i think it takes a couple days to feel the difference but i always reset the ecu after i do a mod so i dunno. maybe i'm doing it the right way or the lazy way. but anywho, about the exhaust, if you want to take a look at my exhaust you can stop by tomorrow anytime before 3, so you can see what yours will look like. it's crazy how good walter is at it. he just measures it with his eyes and it comes out perfect. curves, bends and even the y-pipe. so you'll definitely be happy with it.
Old Nov 17, 2007 | 12:05 PM
B A N N E D
what are the possiblitys of said walter to cusotom make me a full Bpipe with y pipe with a type of mid muffler or resonator and ship it out to MD lol
Old Nov 30, 2007 | 07:54 PM
fuzzy02CLS's Avatar
I'm going to add to this. I'm in the club now. Had the crank pulley installed this afternoon. Only been sitting in my trunk for 3 months.
WOW. The car pulls so hard 1-3 now. This is a must have mod!
BTW I used the option racing pulley on Ebay for $24 & 2 gates belts.
I had a UR pulley from a friend to compare & besides it looking a tad different, It was the same weight & installed the same.
No new vibrations or noises.
Old Dec 1, 2007 | 10:24 AM
J32.4.Life's Avatar
-AKA M.J.H.
I concur. I installed my crank pulley about a year ago and even though mine is a slushbox auto still pulls hard after 3.5K RPM's.
Old Dec 2, 2007 | 03:11 AM
Ditto. I know it's not the same feeling on an auto but ehh, it's a good difference in revs and thats good enough.
Jul 16, 2017 07:33 AM
pistacio
Sep 26, 2015 09:45 AM
iCrap
Sep 11, 2015 06:21 PM
