Unorthodox Racing Flywheel
Old Jan 20, 2007 | 09:21 PM
ThinJim's Avatar
Is this old news? Was checking out some old performace parts websites and came across this. http://www.unorthodoxracing.com/Merc..._Code=clultraL
If that doesn't work, just go to unorthodox and look under flywheels.
Old Jan 20, 2007 | 09:42 PM
CleanCL's Avatar
if i had known about this i would have put it in, even though its technically not difficult to put in, just gotta pull the tranny out. id honestly be suprised if they had more than 1 in stock sitting there. only one way to find out... give them a call. they list it as 13.5 lbs, our stock flywheel cant be much more than that, i have one sitting in my parts shed.
Old Jan 20, 2007 | 09:51 PM
ThinJim's Avatar
Hey what's up? You do know that this is for the manual tranny. the stock flywheel on the manual is 25 lbs give or take a few andd the comptechwheel is about the same as this this one give or take a few.
Old Jan 20, 2007 | 10:40 PM
CleanCL's Avatar
oh ok, i was getting it mixed up with the regular flywheel that the torque converter bolts to. UR seems to make good stuff, someone should it give it a try.
Old Jan 20, 2007 | 10:42 PM
CL FWD SPEED's Avatar
What to do, what to think
interesting.....wonder if its applicable with the 6spd. is anyone using the comptech kit
as well?
Old Jan 20, 2007 | 11:09 PM
dalostpinoy's Avatar
ABP CL-S 6 NAV
as well?
I would say yes, since our 2nd gens only either comes in auto or 6speed
someone should definately rock this. how much hp and torque can the lighter flywheel gain for our cars you think?
Old Jan 20, 2007 | 11:42 PM
Sun Diego CL-S's Avatar
says "hello to my TLX".
on a side note: does anyone know how much a stock crank pulley weighs? i weighed the UR SS crank pulley and that weighs 1.3 lbs.
Old Jan 20, 2007 | 11:51 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Think they're like 8 or 10lbs, atleast that's what I recall reading in the past.
Old Jan 21, 2007 | 12:29 AM
TCM 01 CL-S's Avatar
Uses turn signals in my
8.58 pounds on my bathroom scale.
Old Jan 21, 2007 | 12:43 AM
ABP CL-S 6 NAV
you serious? those OEM crank pulleys are 8.5lbs compared to UR's 1.3lbs? thats straight crazy.
now just imagine UR doing this magic with the flywheel........
Old Jan 21, 2007 | 12:49 AM
i'm guessing there would not be as much of a difference in flywheels as the crank pulleys. i bet Acura techs might give you some shit for having OEM parts during a transmission "repair/replacement".
Old Jan 21, 2007 | 08:00 AM
ThinJim's Avatar
Now that you guys mention the ur pully, that brings up a question. If you remember a few years ago, allmotor destroyed a couple pressure plates with the comptech flywheel. It was later discovered that he had also changed his front pulley to a ur. It might not be a good idea to replace both items as the motor needs some dampning. I have the comptech flywheel and stock pulley up front and have had no issues.
700.00 dollars for an aluminum flywheel isn't bad when comparing it to comptechs price of 1300.00
Old Jan 21, 2007 | 09:47 AM
ABP CL-S 6 NAV
interesting point about the need for some dampening ThinJim. And for less then price of a comptech flywheel, one should be able to get the flywheel/clutch kit (if or when UR makes it)
Someone should contact Mike at UR about these products. I dealt with him before, but just too lazy to email someone right now
mikeh@unorthodoxracing.com
Old Jan 21, 2007 | 11:08 PM
Excelerate's Avatar
Former Sponsor
I didn't even know about this. I will shoot UR an email to get some further info on this setup.
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
0opie
Sep 22, 2015 04:15 PM
