Unorthodox Pulley Set and Injen Question?
I was just wondering if anyone had any sites they knew of where I could get the Injen RD CAI and/or the U Pulley Set from for a 03 CL-S Auto? Thanks
Not a doctor
1 Post
Pulleys you can get straight from the UR website
http://www.unorthodoxracing.com/
for the intake try c-c-c.net they have a lot of stuff for our cars
for all my mods I used www.nopi.com great prices, selection, service, and delivery.
whats the difference between the SS and the SSC pulleys? and Jegs doesnt have it for our cars any more...well thats what they said when i called.
Originally Posted by bim6180
If you're planing to supercharge, get the stock size pulley. If not, get the underdrive
Nope im probably not going to superchage...so the underdrive is the SS? and should i get all three? or which ones should i get?
The only one that gives you gain is the crank pulley, the other two are just for show. It's up to you
I think UR claimed somewhere between 10 - 15 HP. But, you have to dyno your car to know exactly. The engine does rev faster than before (you have to let 4-5 days for the ECU to re-learn and feel the full effect)
Ok i just got the crank pulley....in the little sheet that comes with it, it says to use garret belts i believe. I have goolged that and cant find a site. Does anyone have a link? and does anyone know what belt i can use.
Moderator Alumnus
Originally Posted by GreenMachine
Have John (Excelerate) get you the correct belt sizes.
His name is Josh, and if you buy the underdrive, you have to buy new belts. You can go to unorthodox website, and view the online instruction sheet on the pulley, and it'll tell you the part number for the belts (gates belt). You can either get it from NAPA or any auto supply store.
I'm not sure if you can get this from dealer since it's a different size than the stock one
hope this help
hope this help
Originally Posted by danielsmi
Um the model numbers for the new belts are at the bottom of the instruction sheets. at least it was on mine and everyone else's.
It just has the numbers for the ac/ and alternator. Not the crank pulley. does anyone have the part number? thanks for everyone's feedback.
Moderator Alumnus
Originally Posted by Excelerate
My name is Josh. It is Gates belts K040425 and 060441. Double check though to be sure. The belt #'s are listed on the bottom of the instructions.
There's too many names to remember...sorry
Moderator Alumnus
Originally Posted by dalostpinoy
How many hours does it take a good mechanic to install the set of pulleys and belts?
less than 30 minutes for a good mechanic.
For a full set, about an hour and 15 to an hour and a half. About 45 minutes for just the crank.
braveheart
09-07-2015 08:12 AM
