is THIS under warranty?
Old Sep 7, 2005 | 05:31 PM
aznxtallxboy's Avatar
Question is THIS under warranty?
i was looking around the forums and found this picture. i have the same situation on my driver side door. does anyone else have the same problem? will this be covered under warranty or will the dealerships just try to go around this problem? any answers will be greatly appreciated.
Old Sep 7, 2005 | 06:09 PM
rise's Avatar
I have the same problem. I'm too busy to be bothered with it. Minor aesthetic problem
Old Sep 7, 2005 | 06:11 PM
gsrblack's Avatar
I had mine replaced once already....it's starting to peel away again. I'm still under warranty, so that should be covered for me the next time I take my car in.
But if you leave it, it may peel away even more and by the time you're out of warranty, it will look like crap. Maybe you can just paint the yellow foam black so it won't look too terrible.
Old Sep 7, 2005 | 06:39 PM
dgracer's Avatar
Mine is doing this too but only started after the warranty expired. I've looked into a new part which is $62-$78 but I'm worried about trying to install it myself. not sure how to lift the switch plate for the windows, mirrors out.
Old Sep 7, 2005 | 06:50 PM
CleanCL's Avatar
I had this happen to me.
Solution:
-Remove entire door panel. This is not very hard, 1 screw under the arm area, one screw by the handle. The rest are just snaps. If you search there is a thread telling you how to remove it.
-Once it is off, you will see that section can be removed by about a dozen screws.
-Once removed from the rest of the door panel, I took some extra strength crazy glue, and glued that little groove (you can see it in the picture above). I then wrapped the section i glued in paper, then taped it tightly with packaging tape and let it sit. I wrapped it in paper first so the tape wouldn't stick to the paneling. I let it sit for about 20-30 minutes, and it is all better.
Old Sep 7, 2005 | 07:01 PM
typeR's Avatar
mines doing it too and the dash is looking weird also
Old Sep 7, 2005 | 07:12 PM
was the dealership helpful in replacing/fixing that part? or did they give you problems about that since its such a minor issue? the reason i'm asking is because where i live, there aren't many dealers that givva rats @$$ about minor problems, ex; right muffler hangs lower that left muffler (common problem in CL's)
Old Sep 7, 2005 | 07:44 PM
o1s's Avatar
o1s
mine did it too. i painted it. you can tell if you study it. but it hides pretty well.
Old Sep 7, 2005 | 09:17 PM
dshearon's Avatar
my dealership replaced the whole door panel no questions asked... i showed them it was coming apart and they said ok we will fix it...
Old Sep 7, 2005 | 09:44 PM
erishe69's Avatar
Should be covered under warranty, its a defect in craftmanship.
Old Sep 7, 2005 | 10:47 PM
Shawn S's Avatar
Fix it the "getto" way.
Old Sep 7, 2005 | 10:48 PM
gsrblack's Avatar
no problems from the dealer to fix it....they saw it and acknowledged it. same goes for the dash, had that replaced too because it started to peel away. i think the material they used isn't that great....too soft and can tear or rip easily (the foam, that is). my door panels are starting to tear away again....i may have them fix it again before warranty expires.
Old Sep 8, 2005 | 12:32 AM
great! thanks for all the feedback guys!
Old Sep 8, 2005 | 10:41 AM
spazzz2002's Avatar
Wow i thought i was the only one... I am headed to the dealership... I hope it is covered, however they sold the car to me like that as a Cert-PreOwned.
No loaner, I'm guessing...
Does the TL have the same problem?
Thanks guys...
The Spazzz
Old Sep 8, 2005 | 11:55 AM
treyster's Avatar
A clean ride is in
It seems like this is pretty common. I have the tan interior with the wood grain. I wonder what color I can use....
Old Sep 8, 2005 | 04:24 PM
MotionEffects's Avatar
Acura TLS are SLOW
Yup having the same problem
Old Sep 9, 2005 | 01:11 AM
spazzz2002's Avatar
Made my appointment....
They said that it would be covered under warrenty...
This tread really helped...
Thanks,
The Spazzz
Old Sep 9, 2005 | 08:54 AM
DeezNutz's Avatar
2ManyMiles
I can't believe I'm not the only one! Great thread, fellas!
Old Sep 9, 2005 | 09:34 AM
car_lost's Avatar
i've had all 4 arm rests and the whole dash replaced under warranty.
Old Sep 21, 2005 | 12:54 PM
spazzz2002's Avatar
Angry
Thanks,
The Spazzz
I just got a call from the stealership. They said that my Acura Care Ext Warrty will not cover this ....
I NEED YOUR HELP GUYS, WHAT SHOULD I DO?
Old Sep 21, 2005 | 10:41 PM
What was the reason behind it?
Old Sep 22, 2005 | 08:06 AM
spazzz2002's Avatar
... The reason...
Acura Care is a limited bumper-to-bumper warranty. It only covers defects in parts if they are engine parts. If they put it through Acura would decline...
My next step is to get the Used Car Dept to pay for the fix (I was there when I bought the car)...
Round 1 The Spazzz:0 Acura: 1
Round 2...
Old Oct 3, 2005 | 02:58 PM
spazzz2002's Avatar
Update:
The used car dept is going to make an exception and fix the problem for me...
THANKS ESSERMAN INT'L ACURA- Miami, FL
Good luck everyone else...
The Spazzz
Old Oct 3, 2005 | 03:15 PM
car_lost's Avatar
i hated esserman, but i just heard they got new service advisors and the old one that didnt like me was fired/quit. woohoo!
Old Oct 3, 2005 | 03:20 PM
spazzz2002's Avatar
I have used Sally and Martin...
The dealership to me always seems a little sketchy... But, that's Miami for ya.
Old Oct 3, 2005 | 03:23 PM
car_lost's Avatar
was martin still there when you went?
Old Oct 9, 2005 | 12:47 PM
fuzzy02CLS's Avatar
Any update on this? I noticed mine is doing it as well. I'm going to Palm Beach Acura. It's a 30 miniute drive up the turnpike, but I really don't trust any of the other dealers.
Old Oct 12, 2005 | 09:36 AM
spazzz2002's Avatar
Yes... Martin is still there...
Update: Still waiting on the dealership to receive the part... it have been a week and a half... It is kinda funny, when I had my car there for the first time, they had the part the same day, and wanted to fix it. Now the have to "order" it.
Who knows???? They are probably hoping that I will forget.... (I don't think so).
The Spazzz
Old Oct 12, 2005 | 10:07 AM
car_lost's Avatar
what part are they fixing exactly?
Old Oct 12, 2005 | 10:15 AM
spazzz2002's Avatar
Don't know how to describe it... but, I will try...
On the driver's door, it is the piece next to the window control where the trim meets. The original post should have a pic....
Old Oct 12, 2005 | 10:21 AM
Cruz_msl's Avatar
My Member is Registered
good question, I have aX over here for the pic
Old Oct 12, 2005 | 10:23 AM
Cruz_msl's Avatar
yep, I need a pic.
Old Oct 12, 2005 | 10:53 AM
spazzz2002's Avatar
sorry... the pic doesn't work... i will see if he can repost the pic...
This is a common problem on CL & TL.....
Old Oct 12, 2005 | 12:51 PM
fuzzy02CLS's Avatar
Don't know about that. My 2 old CL's & all my friends CL's & TL's don't have this problem. This new CL I have does though.
Old Oct 13, 2005 | 01:13 AM
here's the picture for the door panel that needs fixing....hope this helps....
you can see the door panel start to peel away towards the bottom of the picture.
Old Oct 13, 2005 | 08:04 AM
car_lost's Avatar
they replace just the armrest or whatever you wanna call it. its held in with a bunch of screws. takes like 10 minutes to remove and replace. i saw them doing it on my car.
Old Oct 13, 2005 | 10:27 AM
spazzz2002's Avatar
the one in the pic isn't that bad yet... Mine is comming out all the way to the top.
jsonkimz
Mar 28, 2016 07:49 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Thuneau
Oct 3, 2015 04:19 PM
hashbrown
Sep 29, 2015 12:13 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
