Umm we got a problem
Old Jan 23, 2005 | 06:26 PM
sexytypes's Avatar
sexier than the sexiest
Since i aint too great with mechanics, since the recent snow storm i took the car out today on the highway nice and clear so i pushed it a little considering the conditions, but the odd thing is that 59mph and below the car rides smooth, 60mph and up the whole damn car shakes and vibrates like its falling apart. Anyone experience this or know what this can be, i have an appointment for tuesday at Acura to have them check it out but what can it be
Old Jan 23, 2005 | 06:34 PM
phipark's Avatar
Not Asian
Check if the tires need to be balanced.
Old Jan 23, 2005 | 06:40 PM
LiQiCE's Avatar
Liquid Ice
Could be tire balancing, could be alignment ... could be a few different suspension related things.
Easiest thing to check first though ... tire pressure! When its cold out, your tires can lose tire pressure like crazy, so you really should check the tire pressure every once in awhile. If you don't already have one, goto your local auto parts store or even Target or Walmart and pickup a digital tire pressure gauge. They're about $10 at most. If you dont have enough air and you don't have an air compressor to pump up your tires, most gas stations have one that you can use for free.
Dont waste $60 at Acura to have them tell you that your tire pressure was low, check that out first.
Old Jan 23, 2005 | 06:51 PM
blackdog's Avatar
When you check the tire pressure take a good look at the wheels and wheel wells. A chunk of ice stuck in the wrong place can make the wheel vibrate like crazy.
Good luck,
Blackdog
Old Jan 23, 2005 | 07:00 PM
CleanCL's Avatar
Good luck,
Blackdog
almost always the culprit when driving in snowy conditions
Old Jan 23, 2005 | 09:30 PM
Brady6226's Avatar
Registered Asshole
tires being low in pressure will not cause a vibration at 60 mph. unless it has no air in it. and if its suspension something is broken. however alighnment being out will not casue a vibration. it would cause a pull. you would have to hit somehing for your alighnment to be out. yes alighnment can be affected by pot holes. but it would have to be some serious potholes. the alightment on the front of CL-S is a tie rod for toe and a seperate bolt for caster. check the lock nuts on the tierods. make sure they are tight. i beleive its a 17 or 19mm wrench.
Old Jan 23, 2005 | 09:49 PM
tommyy2's Avatar
Sounds like ice/snow screwing up wheel balance.
Old Jan 23, 2005 | 10:00 PM
soopa's Avatar
The Creator
you probably have ice in your wheel... this is a common winter problem.... as evidenced by the fact that there is 10 threads about this today
Old Jan 23, 2005 | 10:41 PM
2003TL-S's Avatar
As the other have said, check for ice and snow on the wheel. Tire pressure CAN be a problem too. When your tire pressure is too low and it is sitting for a while it can cause a flat spot on the tire which can give the impression of being out of balance.
Old Jan 24, 2005 | 12:09 AM
sexytypes's Avatar
thanks guys, i just hope its not the tranny, because if it is i am screeeeeeeeeeeeeewed
Old Jan 24, 2005 | 12:11 AM
jazzpicker's Avatar
Old Jan 24, 2005 | 12:26 AM
soopa's Avatar
The Creator
https://acurazine.com/forums/showthread.php?t=166269
https://acurazine.com/forums/showthread.php?t=107981
Old Jan 24, 2005 | 08:15 AM
Red-CL's Avatar
Doin' da crack shuffle
Originally Posted by soopa
you probably have ice in your wheel... this is a common winter problem......
Exactly.
Old Jan 24, 2005 | 08:33 AM
car_lost's Avatar
still vibrating?
Old Jan 24, 2005 | 08:42 AM
EdgarFanCLS's Avatar
Masshole
Key words people - recent snow storm and car suddenly shaking at freeway speeds. 9/10 it's snow or ice packed in the wheels.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
