type s pistons
Old Jun 7, 2002 | 10:17 AM
bryanz3.0cl's Avatar
nothing
type s pistons
anyone know where i can order stock type-s pistons.
Old Jun 7, 2002 | 10:45 AM
SiGGy's Avatar
Moderator Alumnus
Re: type s pistons
I would assume you could no problem from the parts dept. at any Acura delaership. Might take a few weeks.
I'm curious though, what do you want them for?
Old Jun 7, 2002 | 11:08 AM
nothing
raise the compression, im aslo trying to order camshafts and stock cam gears.
Old Jun 7, 2002 | 01:31 PM
xenon7's Avatar
Xe- For Better Hwy Vision
Sounds like a lot of werk to me!
First you will have to mill down the diameter of the 3.2 -10.5 :1
pistons so they will fit the 3.0 cylinders. Second you will have to mill the cam lobes and cut the valves so it will make the clearance for the head.............................................. .....................................
....and so on and so on...................VTEC controller........................
......................porting..................... ....................new injectors......................................... ................................................
My suggestion- buy a crate J32 type S engine and do a swap!
or keep saving your $'s for the real thing.
Old Jun 7, 2002 | 01:34 PM
Type S's Avatar
Powered By HONDA
yah i think u can order from acura parts dept but what do u need that for?they are not going to fit in your last gen cls
Old Jun 7, 2002 | 01:35 PM
SiGGy's Avatar
Moderator Alumnus
Or....
Buy an older 3.2TL engine from a wrecked vehicle.
Since the last body style TL did have a 3.2. Probably be cheap.
Old Jun 7, 2002 | 01:43 PM
Zapata's Avatar
Cost Drivers!!!!
I'm not familiar with the bore and stroke of each but this, as Xenon7 said it will cost MONEY!!! Engine swap will be a better idea. Engine will run 8k plus the custom motor mounts and tranny work.....ugh. Unless you can get this stuff from a junkyard you're better off getting yourself a used CLS.
If you're bore and stroke aren't close to this numbers you're fucked.
3.50 in x 3.39 in (89 mm x 86 mm)
Also remember you'll have to get forged bearings, connecting rods, reworked cams, valves.
Old Jun 7, 2002 | 02:51 PM
tuleman's Avatar
Learn to swim
Good luck with your project. FYI The Type-S pistons are domed. Watch the vavle clearence!!!!!!!!!
SidhuSaaB
May 30, 2020 12:40 AM
Popee
Dec 20, 2015 12:08 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
