Turbo oil return line...
You can turbo anything
You guys that have successfully install a turbo on your cars; How did you run your oil return line? Just getting some ideas before I run mine. Looks like it might be a little tight because it is right next to the downpipe.
My 99TL that is why I am asking on this board. allmotor specifically has the same setup as I am going for...not dire, just curious while I am doing some planning.
ex 6 Speed owner :(
Here's where mine goes:
Straight out of the turbo oil-drain, over the down pipe
Then into the oil pan via a 45-deg fitting. (you can see the line at the bottom coming from the turbo, then into the oilpan fitting at the very top:
i have no idea about turbos on these cars, but i have extensive experience with turboing OTHEr cars, so i want to offer some advice.
ask the manufacturer of your turbo what the desired oil pressure is for that specific turbo.. and MAKE SURE that you will be running that pressure. ie, you prolly cant have a straight dump out of your turbo, cause your pressure will drop too low.
on the other hand if you restict it too much you will blow yours seals, and have a toasted turbo in a few days.
sorry if this post is not constuctive.. i just had to say something
I am getting the oil feed and return line kit from them...my stock pressure is fine...bluecls6 answered my question...
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
