trunk will not open... what do i need to replace??
so my trunk will only open if i reach into the trunk form the backseat and pull the manual release.
i suppose the trunk latch motor (???) is busted.
does anyone know what my next step should be... what part do i need to purchase and replace? part number?
any and all advice is much appreciated.. Thank you!
Jaymann107
The "trunk latch motor" used to pop the trunk may have come loose. Take off the plastic cover and see if any screws are missing. Also with the trunk open and the plastic cover removed use the key fob and listen for a click sound and see if the motor arm is engaging the trunk latch.
My motor has come loose too many times to count.
bentleymp21 (11-08-2011)
Checked before and the switch in the glove box is not the issue. I have stripped the trunk lid and when listening very closely, I can hear a faint tick when I press the trunk release on the key fob, but no mechanical sounds of anything engaging or moving and no visible motion whatsoever. Hmmm... If I can hear a tick, does that mean the motor is not dead but can still be broken?
I Wanna Beer
mada51589
05-03-2022 08:54 PM
TLDude876
12-28-2016 03:18 PM
asahrts
09-04-2015 05:55 PM
