Trunk Rattling...
Trunk Rattling...
It's driving me nuts...!
Each time I the road is uneven or etc., I'd hear something coming from the trunk area that sounds like it is a metal-on-metal rattle. There is no "clanking" sound...it is strictly a rattle.
Anyhow, I think I've figured it out. When my trunk is closed, if I hit the top of the trunk (more towards the spoiler or even ON the spoiler), it creates the same exact rattling sound. I open the trunk...I see nothing on the lid that would suggest something is loose. Then again, perhaps I need to remove the cover to look inside the lid...? I'm going nuts...
Any help would be cool! Thanks!
Originally Posted by CL-Slick
Could it be your jack and wrench, if not fastened they could rattle. Also in mine in the trunk, near the speakers there is a rattle sometimes, could be something loose there.
Could be one the springs that that hold up the trunk... Does the trunk open as it normally does ??
Another one is the 3rd brake light... lots of people report rattles from there...
Unregistered user
it rattles esp. if u have subs.... pos design imo
Okay, I think I've found the problem...there are 2 thin black metal bars that stretch across the top of the trunk right near the trunk's light.
If you close the trunk, I believe these bars also move with the trunk's movement...Anyhow, I hit them and they produced exactly the same rattle as I keep hearing. The question now is: how in the world do I get them to stop rattling? I can't even see what's wrong with them in the first place.
Thanks again, folks!
Chillin' in my trailer
Thanks for the input and help, guys!
The two think black bars are separated at the midway point of the trunk by a piece of metallic (or is it hard plastic?) object. It seems like a separator/brace. I twisted it upwards so that it forced the two bars apart...anyhow, the rattling has stopped.
Originally Posted by aznboi2424
Is the brace still connected to the top of the trunk? Mine wasnt and it didnt hold up the trunk will with my spoiler. Im getting it JB welded and buying new springs. Then taking it to the body shop for a install, might have them permanently weld the brace to the top.
Anyhow, the car will be going in for servicing soon...I'll ask the dealership to have a look.
Yum, FYI those 2 metal bars are the "springs" for the trunk...
https://acurazine.com/forums/showthread.php?t=151648
And that's the thing! That brace has disconnected to whatever it used to be attached to...and I'm guessing it's to trunk lid.
Not Asian
Yeah, the metal bracket may break away from the rear deck. I just drilled two holes in the bracket, drilling out the weld spots. Then, I bolted it up with some lock-tite. That thing shouldn't be moving for 20 years.
Hey guys,
I had a problem with the torsion bars not holding up my trunk lid once I put on an aftermarket wing. The wing looks like stock but a little lighter. Also they kept hitting my speakers. I am looking to take them out and change to struts. Has anyone seen or done that done on a CL??
Yeah, that bracket needs to be rewelded back...I've set up an appointment sometime in September to get it fixed.
Thanks for all the help, folks!
justin.w13.walker
09-22-2015 02:21 PM
