Transmission Temperature
Did a search but might have missed it as I couldn't believe I didn't find the information. Questions are - what is the transmission temperature in stock set up, for those of you with the transmission cooler what temperature are you all seeing, and finially for those of you who are running superchargers or turbos what is your temperature? Thanks Clinton
300F?!? Damn that's some crazy temps. For stock, the normal operating temps I see are around 175F in the summer heat. As temperatures increase above 200F, your transmission fluid's life decreases exponentially.
Originally Posted by YeuEmMaiMai
if you read the very long thread on "what wrong with our transmission" the answer is in there.
The temps go well above 300F in certain circumstances
YeuEmMaiMai- I can see where there is a post that say stock 175 and another that temps run up to 300 and another about breakdown at 200. I just find it hard to belive that a tran. cooler can lower the temp 75 degrees which is what my guage is reading.
joflewbyu2
Oct 8, 2015 11:16 AM
