trans ate itself in 30000 kilometers
Old 10-16-2010, 09:27 AM
  #121
CH46ESeaKnight's Avatar
Originally Posted by CL-S progression 01
even if the clutches got zero oil lubricating them the trans cooler would cool the oil running through the trans which will suck away some of the friction heat that builds up in the physical transmission itself.
so either way it's lowering temps.
Um, how do you supose the tranny cooler will pull heat from the clutch packs if there is "zero oil lubricating them". Not going to happen man.
Besides I thought you said that Jhon at level10 or what ever it is, has it all figured out and the problem is not oil lubricating the clutch packs, but in stead the fault lies in the line pressure. So why worry about oil lubrication?
Dude you are lying to yourself to justify the rebuild.
I compleatly understand if thats all you can afford, but don't act like you found a miricle fix that thousands of people have not been able to find in the last 10 years.
And yes, you said the same thing about your last build! Look where you're at now.
Old 10-16-2010, 01:24 PM
  #122
lowrd on tein CS biatch
CL-S progression 01's Avatar
you guys are too much.
I got you saying one thing,level ten another, and my mechanic another.
1 2 3.
that's 3 different opinions, and i'm only one person. so 2/3 of you aren't going to agree.
anyways...I'm going boatin.
Old 10-16-2010, 02:31 PM
  #123
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,456 Likes on 4,977 Posts
Old 10-17-2010, 12:30 AM
  #124
Ultra Negro
OperationDarkie's Avatar
Dude I feel exactly like the guy in your avatar right now... of course after reading this...
Old 10-17-2010, 08:45 PM
  #125
DaInFaMMuS1's Avatar
this post illustrates that you clearly have no idea how these transmission things work.
Old 10-17-2010, 11:39 PM
  #126
HouseApe's Avatar
In 2005 last modifications were made to cases and internal parts, therefore it is believed that post 2005 replacements are more reliable, but still far bellow of what you would expect from transmission. If your trany was replaced after 2005, and you do regular tranny oil changes, there is a good chance it will last 60-70K miles, maybe even more, its a gamble. No official statistics exist, but what I am saying if it fails you should not be surprised.
Oh CRAP! My next statement will be a clear indication of exactly how little I know about cars....
Ever since I got the tranny changed @ 65Ks (2007).... I haven't done anything with it.... No tranny oil changes or anything...
I religiously do get my engine oil changed every 3000 miles.. but never thought about tranny care...
Old 10-19-2010, 08:24 PM
  #127
pwehmeier's Avatar
Are transmission places (other than NVA) able to do the Odyssey swap?
Old 10-19-2010, 10:29 PM
  #128
civicdrivr's Avatar
Its a relatively straight forward swap. They just need to drill some holes in the tranny housing.
Old 10-19-2010, 11:47 PM
  #129
RoccoRock's Avatar
i had mine done at a local transmission shop. Dont let them try to con you though. All they need to do is swap over components and MAYBE drill and tap the bosses for them. Mine had to be drilled and tapped so it was an extra $75 for labor. I put an 05 Oddy trans in my 01 CL-S. Works fine. Altogether it cost me about $2000. They also had to replace the trans mounts since they were shot.
Old 10-20-2010, 08:12 AM
  #130
3.5 psi
gnuts's Avatar
good listening!
Old 10-20-2010, 08:57 AM
  #131
Missing My CL-S
SG81's Avatar
01clsprogression, i'm saying this with no interest in what you do ...or don't do. If you really can't go the 6-speed route,
SELL THE CAR ALREADY!
Old 10-20-2010, 04:14 PM
  #132
ordered the rebuild kit from level ten. it's on a plane already.
6 speed is going to be the project down the road. i'm going to be buying parts over the next year, or 2 so if/when it fails I got everything there set to swap over.
so you can all stop dwelling on this thread. plan is already in motion
P.S i will never sell this car.
Hell i may just buy a 6speed cl-s instead of gathering parts. then i could have one to RIP on, and the other for daily driving. But i'm sure you fellas will disagree with me again on that decision as well
Old 10-20-2010, 06:36 PM
  #133
e r y k's Avatar
stop driving like a ricer, it might make your tranny last longer.
why keep re-buildling an auto thats known to fail over and over? by now you could have done the 6 speed swap.
on the flip side, if you saved money instead of buying ricey shit like a volt gauge and whatever pointless gauge for your car, it might not be so hard on your wallet.
Old 10-20-2010, 07:46 PM
  #134
russianDude's Avatar
Did he also say that he was drag racing it for some time? Bad idea, as weak as these trannys flooring your car will definitely make your tranny fail.
Old 10-20-2010, 08:13 PM
  #135
I think it's a great idea to buy a 6 speed, 1 for fun and 1 for DD duties. Its simpler than swapping and you have no downtime waiting to complete the swap.
Old 10-20-2010, 09:18 PM
  #136
I Drive Like A Dick 8≈
Nersh7's Avatar
Old 10-21-2010, 07:45 AM
  #137
well this kit has a lot in it!.
Old 10-21-2010, 08:01 AM
  #138
Hey, are thoes Acura OEM parts? Looks like it to me!
Nah J/K man, just messing with ya.
Old 10-21-2010, 08:43 AM
  #139
after looking further at the package... the clutches are made by altousa.com
they look pretty good after going on their site.
Old 10-21-2010, 08:58 AM
  #140
Missing My CL-S
SG81's Avatar
i understand your 'CL love' and i really hope it works out for you, but i don't want to see you waste your money if it fails again. Good luck though
Old 10-21-2010, 10:02 AM
  #141
so i dropped off the kit to my mechanic at the DLR he works at. he showed me an mdx he's building there. showed me brand new oem clutches. they are GARBAGE. no wonder they fail. the clutch material is patched on which ends up breaking off, very poor design.
the ones in the kit I go were one piece encompassing the entire clutch surface. plus it was obviously put on much much better.
Old 10-21-2010, 01:25 PM
  #142
Justin's
98JDMCL's Avatar
where you getting it done rob?
Old 10-21-2010, 01:59 PM
  #143
same guy who did it before. but this time for cheaper since he's doing it again and feel bad for me.
with the better parts and cooler from the beginning this time and me not racing the car around.. it'll be good for 100000kms is my estimate. that's 3 years.. by then many things will be different
Old 10-21-2010, 03:14 PM
  #144
p.diddy's Avatar
lol thanks for the laugh.
Old 10-21-2010, 03:23 PM
  #145
anytime
Old 10-21-2010, 04:11 PM
  #146
Nersh7's Avatar
Originally Posted by p.diddy
[/b]
Old 10-21-2010, 04:49 PM
  #147
civicdrivr's Avatar
Woah! That kit doesnt fix the #1 problem with these trannies!! Who'da thunk??
Old 10-21-2010, 09:57 PM
  #148
Hopefully with the upgraded clutch material and less aggressive driving the clutches will last longer than we expect, but in the end the design flaw is still present and future failure is imminent. Gives u time to go find that 6 speed though
Old 10-22-2010, 11:46 AM
  #149
pwehmeier's Avatar
Don't you think you should get more than three years out of the tranny considering everything you put into this?
Old 10-22-2010, 02:37 PM
  #150
well obviously I am hoping this will fix the issue for the unforseen future, but I can only anticipate 100000kms realistically.
like I said the stock clutches are just pathetic... no disrespect to anyone, but having both in my hands comparing the two it's quite obvious how much stronger and rezilliant these alto clutches are.
My guess is they will actually engage firmer than the oem ones also, thus I should go a tad bit faster. but who knows.
All I care about is getting my baby back.
Old 10-22-2010, 06:10 PM
  #151
civicdrivr's Avatar
well obviously
Old 10-22-2010, 06:34 PM
  #152
3.7L Nitrous Breathing CL
richardparker's Avatar
When are you to have your car back ?
can't wait for the reveiw
Old 10-22-2010, 10:36 PM
  #153
will have it in under a week
Old 10-22-2010, 11:09 PM
  #154
B A N N E D
friesm2000's Avatar
just pick up a 6-speed already...
Old 10-23-2010, 07:27 AM
  #155
thats all, 100,000kms? thats like 60K miles, even OEM transmissions typically work that long
Old 10-23-2010, 10:32 AM
  #156
i'm not aiming for the stars.. all i know is 100000kms is definitely feasible
Old 10-23-2010, 06:56 PM
  #157
Rapture's Avatar
Alright, well I hope it works out well for you. tbh despite whatever premonitions there might be, it'd be nice to know there's another good solution for those of us who have automatics.
I mean, if 6 speeds were so easily available all over the country, I know the 5ATs around here would be few and far between.
Old 04-09-2011, 04:06 PM
  #158
You have had the rebuild done for awhile now.
How does your trans feel compared to the stock rebuild.
Any signs of slipping yet ?
Old 04-09-2011, 05:51 PM
  #159
I got the Shifts
phee's Avatar
i went through three trans in 1 yr.. all rebuilt by acura.
Old 04-09-2011, 09:20 PM
  #160
not at all man, car feels amazing still with nothing my anal self can complain about.
All that's bothering me right now is I lowered the car and it's still out of spec on the drivers side camber by +0.2 and the caster was not touched and it's at 2.6 and 1.8 and the stock caster should be 2 degrees positive..... but w/e i will go somewhere that knows what they are doing to get that done.
all is well.
Quick Reply: trans ate itself in 30000 kilometers
