Tranny Flush at 30k?
Just wondering if I should have a tranny flush done at the dealer when I hit 30k it's mostly highway miles, but I do live in northern Jersey which is stop and go traffic hell god this states highway system is the worst ever, I'm at around 25K now....I'v got an 03 CLS, that is not included in the tranny recall, but think I should have it done just to keep the tranny in good condition.....
IMO, it couldn't hurt to change it, especially if you do a fair amount of in town driving (the car will do a lot of shifting if not put into D2 or D3). ATF degrades with time, and the ATF gets very hot inside various parts of the transmission (inside the second and third gear clutch packs for example).
BTW, I'm also aware that there are a few people that believe that changing the fluid leads to transmission failure. (IMO, the logic used to arrive at that conclusion scares me.)
Yes I also read that a flush or change could lead to quicker failure, but there was a huge debate thread on this...I was thinking of just doing a flush, rather then a change right now, maybe a full change would be more apropriate....My feeling is a flush would be cheaper then a change but I'll have to investigate that....
I flushed mine with 9 qts. synthetic,,
http://www.amsoil.com/products/atf.html
Now I just change it with synthetic( 2.7 qts) every 15k miles,, IMO a flush is not needed with synthetic changed every 15k. I'm still on the orginal trans nearing 60k miles. (knock on wood)
Flush/change -> iterative method used by Acura
Originally posted by louisn
Are we talking about a "change" or a "flush." My dealer told me a flush was much better but cost more than double???????Any comments??
Comptech said that they did use a non-Acura tranny shop to "flush" the "slushboxes", but they did mention that they did check to see that the process was compatible with the transmission. (I can't comment on this, as I have not used this process.)
Here is the link to the factory method/iterative method for flushing/changing (Jens and others brought the info here):
http://www.acura-cl.com/forums/showt...ighlight=flush
Originally posted by EricL
Do I hear an Echo, Echo, Echo, Echo????
Originally posted by fender4
Hummmmmm now how did that happen??? Computer wasn't allowing any sends so I guess it was and I didn't see any return,, ECHO it is I guess,,, can't figure out how to delete old threads. ???
a ticket to ride...
dgracer:
You and me both. I change my ATF every about every 10K or 3 oil changes. Have an early 01 CL-S @ 67K mi. Never a tranny prob and I've gate shifted hard 'everyday' since day one.
loiusn:
As to whether or not to have your Acura dealer "flush" or "change" your ATF, have them "change" the fluid. Depending on the dealership, flushing would entail using a machine to force flush the fluid in/through the tranny. As someone early had mentioned that he heard changing/flushing fluid may actually damage the tranny, is somewhat correct. "IF" your tranny fluid has not been flushed in many miles and is very dirty, "flushing" the fluid can actually force particals in the gear packs - bad - the idea of course is to remove the particals through the fluid drain. If this is your situation, then "change" your fluid multiple times - drain, fill, run, repeat. If not, just change it regularly. This is even an "internal" Honda recommendation from what I've heard from my Acura tech. Using the flushing method is really another way for the dealer to have a higher markup service and charge extra for other things like tranny additives - which really don't help much. Good luck.
loiusn:
