Tranny Fluid Leaking
Old Jun 22, 2006 | 08:21 AM
Moodist's Avatar
Mods, I just wanted to put this in the main forum so I can get some more visibility.
When my headers were being installed, the shop let me know that my transmission, the area around where the drain plug is cracked. This is leaking tranny fluid every so slightly. I changed the tranny fluid, but everything was torqued up to spec. The shop said most likely air tools over-torqued the nut causing the casing to crack a bit. I am perplexed how this may have happened.
Anyone else have this issue? Two solutions are to get the tranny casing welded or replace the entire casing. Any other ideas?
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
