Tranny failure guys
Old Mar 26, 2010 | 04:55 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Tranny failure guys
I have noticed a few trans issues the last couple days.
First,if I back out my drive way and then put the car into drive it takes 2-3 seconds before engaging.
If I floor the gas while driving at regular speeds 5-10 times the car instintly "like" goes into neutral and the rpms will soar like it was sliping but,it does not seam to be sliping.
Also if I floor it right off the line like draging it will not do it at all??????
One time I pulled into a parking lot with a slight inclined and after I made it to a flat it totally would not shift to anything.
shut off the car restarted and it was fine.
Any idea's.
pumps, filters, sensors,etc.
Or is the trans just on it's way out ?
Old Mar 26, 2010 | 05:12 PM
fsttyms1's Avatar
you could try changing the fluid and cleaning the solenoids and see if it helps but it sounds like a trans onits way out.
Old Mar 26, 2010 | 05:15 PM
fsttyms1's Avatar
https://acurazine.com/forums/showthr...=756425&page=2
Old Mar 26, 2010 | 07:21 PM
Jacobpockros's Avatar
Tranny is failing. Those are all the symptoms to my knowledge.
Maybe try to do the 3g TL auto swap
Old Mar 26, 2010 | 07:34 PM
What would be my best option price wise ?
If I do some kind of swap I want it to be done once.
I know it's been beat in the head but,I plan on digging in the motor for more power "maybe" and would need it to handle far more than stock.
Old Mar 27, 2010 | 06:56 PM
fuzzy02CLS's Avatar
No one has swapped in a 6MT to a CLS or CLP.
Old Mar 27, 2010 | 07:48 PM
CL-Slick's Avatar
Chillin' in my trailer
I think one member has on here if I'm not mistaken. He has a black CL-S, and I'm pretty sure he recently did the swap. Mine just went out last night, so I'm all ears for advice.
Old Mar 27, 2010 | 08:23 PM
anthracitecl's Avatar
sounds like trany going bad. try what fsttyms1 said first, then see what happen.
nspec-ya4 did 6spd swap in his cls.
Old Mar 27, 2010 | 11:11 PM
dsickles's Avatar
and it was a bitch. lol
i would say, if your not ready to take on a 6speed swap, then try and put the 07-08 tl base transmission in.
Old Mar 28, 2010 | 07:26 AM
MrFluffy's Avatar
To many cars in my garage
Do the oddysee or tl swap its the cheapest and the best IMO
Old Mar 28, 2010 | 08:06 AM
p.diddy's Avatar
Originally Posted by mrfluffy
do the oddysee or tl swap its the cheapest and the best imo
+1
Old Mar 28, 2010 | 02:11 PM
BigLizard's Avatar
Moderator Alumnus
OP, my cl-p did the same when the transmission went out. I got around 125,xxx miles on it before it died.
Old Mar 29, 2010 | 09:11 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
sounds like a dying tq converter..
if it makes u feel any better my original trans only lasted 57K miles
Old Mar 29, 2010 | 09:33 AM
ThegreatGATHby's Avatar
Similar symptoms I had last week, now i'm in the shop waiting for a new tranny.
Old Mar 29, 2010 | 01:26 PM
cu0ngsayz's Avatar
if i was you i'd sell the rims and do a 6speed swap
Old Mar 29, 2010 | 03:03 PM
Rapture's Avatar
It's funny how people keep suggesting a 6MT swap as if the transmissions are so easy to come by.
Old Mar 29, 2010 | 03:14 PM
norcal-cls's Avatar
Everyone keep talking about the odyessy or 07 tl swap, does anyone have a thread on the swap? What does it need to do the swap? or does it bolt right up? I am curious and would like to know asap. Got to get myself ready for this kind of problem.
Old Mar 29, 2010 | 03:27 PM
victorvu's Avatar
i think the only difference might be a mount and sensor.
Old Mar 29, 2010 | 03:28 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
dont do a 6 speed swap unless u have a complete wrecked car.
it is a little easier to do if ur CL is 03. but i think urs is 01.
i think i'll make a list of parts needed for the swap.
Old Mar 29, 2010 | 03:34 PM
Hey, [thread jack warning] my transmission is being rebuilt currently. Should I not have them replace the dealer bandaid fix of dumping part of the fluid to the filter back into the fill hole if I am getting an external cooler?
Old Mar 29, 2010 | 03:47 PM
MD03CL-S's Avatar
Here you go...
https://acurazine.com/forums/2g-cl-problems-fixes-70/another-solution-my-auto-cl-guys-758220/
Yikes
May 3, 2021 04:29 PM
Junior Noboa
Sep 21, 2015 06:28 PM
Rob144
Sep 21, 2015 08:18 AM
kuzdu
Sep 10, 2015 08:42 PM
HeloDown
Sep 8, 2015 06:51 PM
