TPS Sensor Replacement
Old Feb 17, 2005 | 03:27 PM
WILLDOGS's Avatar
I shave my change purse
Sometimes when the car is warm and I go to start it up, it takes a while and/or the idles starts loping up and down. I had a CEL come on not too long ago and the dealer said it was "Low Voltage to TPS"
I am assuming that my TPS is taking a dump slowly since this only happens after the car is warmed up already.
Question: Can I replace the Throttle Body myself? I understand that you need to replace the whole TB since they do not sell the sensor on its own?
#2 Is it worth getting the CL-S TB? I've seen some people here say that the CL-S TB is a nice upgrade for the CL-P, but I need to know if it is just plug and play? Or do I need to modify anything else?
This problem only happens very infrequently, but it is annoying when it does happen.
Old Feb 17, 2005 | 03:29 PM
WILLDOGS's Avatar
PS I 've already tried cleaning the TB with TB cleaner but the problem still exsists.
Should I maybe try cleaning the TB with the car running this time? When I cleaned it the car was off and I sprayed the whole thing down like a wildman and let it dry before starting it.
Old Feb 17, 2005 | 03:36 PM
JaredGMS's Avatar
Meat stick
is that the sensor that alerts the boss about not reading TPS reports?
ummm..that's my stapler
Old Feb 17, 2005 | 03:55 PM
WILLDOGS's Avatar
Old Feb 17, 2005 | 07:57 PM
WILLDOGS's Avatar
bump
can anyone lead me in the right direction? I am searching as much as I can but I can't search for "TPS" cause the phrase is too short and I am not getting many answers
thanks
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
NSolace
Sep 3, 2015 08:02 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
