TPS Sensor
Old Jun 15, 2007 | 06:38 PM
Sly Raskal's Avatar
TPS Sensor
Is the TPS sensor on the Throttle body replaceable or is it riveted to the TB?
I don't remember what someone had told me in another post, all i do remember is them mentioning that King motorsports MAY be able to replace it.
Old Jun 15, 2007 | 06:39 PM
Sly Raskal's Avatar
Also, what are the signs of a TPS sensor going bad? What is a way to check for a bad TPS sensor?
Old Jun 15, 2007 | 06:52 PM
CleanCL's Avatar
check TPS voltage, and you cannot purchase the TPS separate, only way to get it from the dealer is to buy the whole throttle body.
Old Jun 15, 2007 | 06:56 PM
Sly Raskal's Avatar
Is there information in the Helm's manual on how to check the TPS voltage?
How much does the whole throttle body run?
Old Jun 17, 2007 | 08:51 AM
CleanCL's Avatar
theres another thread floating around where i posted the voltages, just seach my username for posts by and TPS* or throttle position, should come up.
brand new throttle body: $265 at www.oemacuraparts.com
-that includes new TPS, new MAP, and new IAC
Old Jun 17, 2007 | 09:21 AM
SPoolinspOON's Avatar
OG 3.x^7 rawr
voltage should run ~.45v closed
open at ~4.5-5.0
Is there a CEL. You can just replace it but I have yet to find the right TPS that will work. Jorge at Maxbore might have one. Give that a shot.
Old Jun 17, 2007 | 09:25 AM
CLS6SpeedNupe's Avatar
lol....mines went last week this same time. Took it to a shop monday and they called the dealer who said it they have to buy a whole new throttle body for like $400 bucks. The dudes at the shop thankfully were a little expreinced in hondas so they said they could pull a sensor of a Integra i think and rig it to work on my car. So they did that and everything worked perfect. Ened up paying $210 for everything. So screw a whole new throttle body, if u can get one off an integra and install it yourself then you will save a lot more than i did.
Old Jun 17, 2007 | 10:12 AM
CleanCL's Avatar
brand new TB w/ EVERYTHING for 265, yet you paid 210 for a rigged TPS... not sure, i woulda went with the whole new one.
Old Jun 17, 2007 | 10:14 AM
CleanCL's Avatar
heres the info right from the HELMS:
fully open: about 4.8 V
full closed: about 0.5 V
Old Jun 17, 2007 | 10:42 AM
yea maybe i would have to, but did i say anywhere in my post that $265 for a new TB was an option????? no I dont dont think I did, you did. And im sure you would have done the same time I did had if you didnt know u could new a new one at that price to.
Old Jun 17, 2007 | 11:16 AM
CleanCL's Avatar
first of all, i never let the dealer touch my car. i do all my own work, or have my personal mechanic do it since he will install parts that i purchase.
second, you are telling the guy he will save a lot of money by buying an integra TPS, and i was pointing out that the difference was roughly $50 for a brand new one with all new sensors.
Old Jun 17, 2007 | 11:39 AM
Sly Raskal's Avatar
Thanks for the info bud, I looked it up on that site, and it didn't list a part #
The only reason I ask, is beacuse is, are the throttle bodies for the 6mt the same as the TB for the 5at? I thought they were different because of VSA? Am I way off here?
Old Jun 17, 2007 | 04:18 PM
Sly Raskal's Avatar
Alright so I looked up the sensor in my helms manual, I found the location where the harness plugs in to get the values for the TP Sensor.
Do I literally just stick in voltmeter leads into the correct slots to read the voltage?
Sorry for the questions, this is all new to me.
Old Jun 17, 2007 | 05:00 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
My Check engine light was on so i went to pepboys to do the free diagnostic test and it happend to be that my TBS was on low voltage... Now I may just have to replace the cell on it. good lick with yours.
Old Jun 17, 2007 | 06:41 PM
CleanCL's Avatar
the VSA throttle body for the autos is an entirely separate unit, here is the part number for the regular throttle body:
16400-PGE-A12
Old Jun 18, 2007 | 04:57 PM
Sly Raskal's Avatar
^^^ ahhh ok, thanks.
Now I just need to figure out how to check the voltages before I buy the TB
Old Jun 27, 2007 | 05:41 PM
Sly Raskal's Avatar
Alright so I'm still confused, how do i check the voltages on the TPS sensor.
If I get a voltmeter, I don't knwo where I should be hooking it up to.
Old Jun 28, 2007 | 04:27 PM
TheWeez's Avatar
I Wanna Beer
Yes in most cases you stick the multi-meter into where the wires go into the unit.
Old Jun 28, 2007 | 07:37 PM
ThinJim's Avatar
I'd almost bet this would work. you just drill out the goofy rivets and screw this one in. volts are volts. although our car isn't listed doesn't mean this one won't work. Look at the mugen cooling mods for the prelude that works on our cars. but you never know.
http://www.kingmotorsports.com/category.aspx?cat=61
Old Jun 28, 2007 | 07:39 PM
ThinJim's Avatar
You could have tried this, i would risk 80.00 to save 400.
Old Jun 28, 2007 | 09:42 PM
Sly Raskal's Avatar
^^^ where do you get $400 from? An OEM throttle body is about $200 if i recall from one of the oem part vendors on the net.
that is a nice find though. What is the voltage rating on it? Does the high and low match with the OEM TPS sensor?
Old Jul 18, 2007 | 03:32 PM
italiaCLs's Avatar
yeah.. great find.. i wonder if it works though..... anyone know???
Old Jul 18, 2007 | 03:35 PM
Sly Raskal's Avatar
I still haven't tested my TPS sensor because I don't know where to plug the leads off of a voltmeter. :help:
Old Jul 18, 2007 | 05:41 PM
italiaCLs's Avatar
If you go to autozone or something.... they will hook it up to your OBD 2 and it will tell you what the volts are... That is what I did. My volts are .07. I am trying to find a sensor from omnipower. Good luck-
Old Jul 18, 2007 | 05:42 PM
Sly Raskal's Avatar
Guess I'll give that a try...
thanks!
Old Jul 18, 2007 | 06:47 PM
italiaCLs's Avatar
im wondering if any of these will work.
http://www.streetimports.com/products.asp?catid=187
Old Jul 18, 2007 | 06:53 PM
Sly Raskal's Avatar
^^^ $99
a brand new TB costs $200. I'd rather just buy a new TB for $200 if I'm spending $99 on just the TPS sensor
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
