tire is leaking air in the cl-s
Old Oct 29, 2005 | 03:44 PM
TypeSblkura's Avatar
JAPAN
hey guys i recently dropped my car on some tein ss coilovers and the front driver tire is leaking air very slowly. I can tell after a couple of days that the tire is deflating after i fill it up. Even with new tires, what should i do???
_noob_
Old Oct 29, 2005 | 04:03 PM
Zippee's Avatar
How much pressure are you losing?
If the tires are new I'd go back to where you bought them for a look.
Old Oct 29, 2005 | 07:00 PM
R J Poseidon 6's Avatar
~HondaF1~
Yeah, I don't think it has anything to do w/the lowering...
Old Oct 29, 2005 | 07:09 PM
crazytsxmods's Avatar
Theres probably a bad bead somewhere. Either one of the tires is damaged from improper mounting witch can occur. My guess would be a small bend near the outter lip of the wheel at the bead.
Old Oct 29, 2005 | 07:11 PM
Take the tire off and fill a rubbermaid bin with a little bit of soap in water. Turn the tire slowly untill you see allot of bubbles. That should be where the leak is coming from.
Old Oct 29, 2005 | 10:03 PM
Lord Helmet's Avatar
I'm here in spirit...
Check the valve stem too...
Old Oct 29, 2005 | 10:15 PM
Russdaddy's Avatar
Boondocks fanatic.....
From: Half-assed Aggie trapped in Longhorn territory....
Take the car to the place where you bought the tires from. If they are the stock tires and the warranty is expired, then take the car to a place such as discount tire or NTB. They fix leaks at a pretty good price and if you got the tires from them, they fix flats/leaks for free, no questions asked.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
cycdaniel
Dec 17, 2019 10:58 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
Rexorg
3G MDX (2014-2020)
Sep 6, 2015 11:31 AM
