Tips for 60k checkup?
Old May 13, 2003 | 08:45 PM
Doc.Booty's Avatar
I'm dropping the car off for her 60k Thursday. What should i know?
Old May 13, 2003 | 09:02 PM
Smitty's Avatar
Sell sell sell... lol.. just kidding..no seriously, trade it in...LOL.. nah just kidding there too..
NEED SERVICE?
We're ready to help. And we can do a better job in less time if you can tell us as much as possible about what's happening. Just check off any of the appropriate boxes below, and add any relevant comments in the fields provided. You can use the glossary of Vehicle Sounds and Acura diagram to help you describe noises and pinpoint their sources.
When you're finished, simply print out the form and bring it in to your Acura Service Advisor. Thank you for giving us the opportunity to ensure that you and your Acura receive the high quality service you deserve.
Engine
Does not start Stalls when decelerating
Does not turn over Idle speed is too high
Difficulty turning over Knocks or pings
Hesitates Backfires
Noticeably poor gas mileage Unsteady Idle
Stalls when starting
Noise & Vibration
Noise When braking
Vibration When accelerating
Both apply When decelerating
When in reverse When turning
During normal acceleration
During normal deceleration
When engine is running and vehicle is moving
When engine is running and vehicle is not moving
Transmission
Difficult to shift, does not shift properly
Shifts prematurely or slowly Slippage
Does not upshift Shifts harshly
Does not downshift Will not shift at all
Makes unusual noises when shifting
Brakes
Front brakes Rear brakes
Both front and rear Unable to determine
Brake pedal must be pumped continuously for vehicle to stop
Brake pedal must be depressed fully for vehicle to stop at any speed
Vehicle pulls to one side when braking
Brakes make the following sounds:
Squeaking Grinding Squealing Rattling
Front End Alignment/Steering & Handling
Vehicle shakes when in operation
Vehicle vibrates when in operation
Vehicle ride is rough and uneven
Excessive steering required for vehicle to stay on course
Steering wheel feels "tight" when making turns
Steering wheel feels "loose" when making turns
Body & Paint
Repair required:
Body work Panel Alignment
Paint work Air leaks
Water Leaks-where:
Hood Right fender Door panel
Roof Right quarter panel
Trunk Left fender Grille
Left quarter Panel
Heating & Cooling
Air conditioner does not have any cooling effect
Air conditioner not cold enough
Air conditioner takes an abnormal amount of time to cool interior
Heater does not have any heating effect
Heater does not have proper heating effect
Heater takes an abnormal amount of time to function
Air flow does not function properly
Air flow does not function through the following vents:
Center Driver-side Passenger-side
Floor Defroster
Temperature fluctuates greatly
Difficulties with air intake:
Recirculating air Outside air
System makes unusual noises or vibrations
Hearing an unusual sound? After you
print this form, draw an 'X' where the
noise seems to be located.
Vehicle Sounds
The following noises may help you in detailing your vehicle's condition to your service advisor.
Booming - rhythmic sound like a drum roll or distant thunder.
Buzzing - low-pitched vibration, similar to that of a bee.
Chattering - a clicking metallic noise that repeats rapidly.
Chirping - high-pitched noise similar to a bird.
Clicking - rhythmic tapping sound similar to that of a ball-point pen.
Clunking - a dull thumping, like something being dropped.
Grinding - a loud abrasive, metallic noise, often high-pitched.
Growling - low noise like that of an animal.
Humming - continuous noise which may be somewhat melodious.
Knocking - a banging noise with two objects hitting (heavy vs. light) one another.
Rattling - shaking sound, as if something is loose.
Rumbling - a low, gurgling noise.
Squeaking - high-pitched metallic sound, often continuous.
Squealing - high-pitched whine as if something is tearing.
Tapping - light hammering noise that can be rhythmic or intermittent.
Thud - low-pitched metallic thumping.
Thumping - a loud, banging sound.
Whining - high-pitched buzzing sound.
Electrical
Is there a problem with:
Lights:
Front Reverse Taillights
Left turn signal
Hazard
Right turn signal Glove box
Interior dome Lighter
Dashboard display
(Please describe: )
Power Windows:
Front driver-side Rear left
Front passenger-side Rear right
Sound System
AM/FM stereo cassette
AM/FM stereo
Compact disc player
Front speakers
Rear speakers
(Please describe: )
Windshield wipers
Windshield wiper spray
Driver's seat adjustment
Rear defroster Power locks
Rearview mirrors Security system
Other
Please describe in detail any previously checked item, or add other items not listed.
Priority Service
Of the service items listed, please indicate order of importance:
1.
2.
3.
4.
5.
Old May 14, 2003 | 01:54 PM
BSK181's Avatar
do it at a private place, acura gets too much $$$$$
Old May 14, 2003 | 02:24 PM
CO-CL-S's Avatar
Re: Tips for 60k checkup?
You should have shopped around for the best deal. You should have asked what the dealer is going to do (follow the Acura schedule Normal or Severe?) other?..
Old May 14, 2003 | 03:34 PM
Doc.Booty's Avatar
Re: Re: Tips for 60k checkup?
They're doing the normal. I change my own oil, etc. I just wanted to know if they'll tack on anything extra that i don't need - the projected price of the visit is around $400 i believe.
Old May 14, 2003 | 03:37 PM
CO-CL-S's Avatar
Re: Re: Re: Tips for 60k checkup?
Mine was a little under $250.00 so I hope they're doing something extra for you..
Old May 14, 2003 | 03:45 PM
Doc.Booty's Avatar
Re: Re: Re: Re: Tips for 60k checkup?
That's just what i remember from the board at the dealership last time i was there, it could be way off.
Old May 14, 2003 | 04:38 PM
Fabvsix's Avatar
Cajun Gumbo Man
Don't bend over !
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
c1souk
Sep 28, 2015 11:20 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
ivan06106
Sep 26, 2015 04:38 PM
