Throttle problem!!
Old Nov 17, 2010 | 06:25 PM
ironsurfer129's Avatar
CL-Pride
Throttle problem!!
I am experiencing throttle problem with my car. I have been driving this car for two years and I am very familiar with the throttle.
Recently I am having trouble stepping on gas from stop. I tap the pedal as usual and the pedal feels like it is stuck or something, and i will have to tap harder and my car will accelerate hard out because I step too much.
I thought its the air filter but nope, wat other problems could it be?
FYI, I did change my transmission recently. I am going to try seafoam soon
Old Nov 17, 2010 | 06:27 PM
How many mileage on the car?
have you changed your plugs?
Have you taken a look at the throttle body? it could be dirty.
Does it stutter?
When you seafoam, you should also clean out the throttle body entry way and its butterfly valve.
Old Nov 17, 2010 | 06:43 PM
When you say you changed the transmission, what does that mean?
A different one?
A shop did it?
Old Nov 17, 2010 | 07:19 PM
phee's Avatar
I got the Shifts
sounds like a dirty throttle body
Old Nov 17, 2010 | 07:39 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
either what phee said or ur cable needs some grease
Old Nov 17, 2010 | 09:36 PM
CL-Pride
change my transmission as in my old transmission died, i will definitely try to clean the butterfly valve
Old Nov 18, 2010 | 10:06 AM
StreetKA's Avatar
Spray some wd40 to throttle cables. And clean it also clean IM if you are doing this kind of stuff.
Old Nov 18, 2010 | 10:39 AM
fuzzy02CLS's Avatar
Yep. If not cleaned & with high miles a ring can form around the TB plate. Causing the plate to stick.
Old Nov 18, 2010 | 12:09 PM
rlpierce04's Avatar
I had this same problem. When I had my timing belt changed, they said my throttle body needed cleaning(I didn't tell them about the throttle sticking). After reading this I realized that the throttle hasn't stuck since then. So, I'm going with TB too.
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
