Throttle Body Spacer with CAI - ????
I got a P2R TB Spacer and gaskets from Excelerate. I was wondering if there are any fitment issues with a CAI?
It seems that using a TB spacer shifts or lengthens all the intake stuff about an inch to the right. What can I do to make sure my CAI will still clear and fit into that hole in the frame?
lowrd on tein CS biatch
it will fit in the hole just fine but your polyurethane mount will not work anymore... i made a lil bracket out of sheetmetal and cut the mount in half and used it to bolt the sheet metal to the intake bracket ...
if i could weld i would have just cut and re welded the bracket on the intake... it'd be quicker and easier
Both good suggestions. Thanks guys. I'll see what it looks like after the install. I used a silicon coupler between the TB and the MAF assembly because my rubber tube tore. Maybe I can do some more cutting from that, that way I don't need to do any welding and stuff.
Thinking about it more, cutting the CAI length might be the best bet, u think a hacksaw would do the job right? I don't have a chop-saw or any other precision equipment.
As for how to cut it, just cut it with a hacksaw. Mark off the distance you need to cut it in a few places and Run a piece of tape all the way around it so you have a line to follow.
You dont need the little bump on the end to make a tight seal. As for selling it, sell it with the spacer. Done deal.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
