Throttle Body Assembly
Old Jan 7, 2002 | 11:41 AM
jhouse's Avatar
Mild Mannered Reporter
I hadn't driven my car in about 2 weeks. I took it out Saturday and it was idling funny. I drive to the store and back. On the way back, the car jerked and all the lights on the dashboard came on.
I brought the car in today and they told me there was a problem with the Throttle Body Assembly, amongst other things.
Anyone esle with this problem?
Just wondering!
J
Old Jan 7, 2002 | 12:18 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Re: Throttle Body Assembly
Just wondering!
J
That my dear sir is not something with the throttle body....it is your tranny...
Did it make hard jerking like it was in neutral and than suddenly popped into gear?
Old Jan 7, 2002 | 01:25 PM
jhouse's Avatar
it wasn't like the transmission. I've felt that before in other cars. If it is, I'll make sure i get it replaced.
Thanks for mentioning it!
J
Old Jan 7, 2002 | 02:34 PM
J
Hmmm....jerky tho...any other symptoms?
Old Jan 7, 2002 | 02:38 PM
jhouse's Avatar
in neutral, the car would rev at 1, then go to 2.5, and then back to 1, etc.
the tranny felt fine.
when i first got in the car, the accelerator was stuck, i push it through, then the rough idle, then the lights on the dash came on...check engine, vsa...
they say they know the problem, i'll post more tomorrow when i see the repair order.
J
Old Jan 8, 2002 | 01:21 PM
jhouse's Avatar
Throttle Body - Fixed, but I need an explanation!!
according to my service order, the tech pulled code 0505 idle control. after following the acura flowcharts, he found that the IAC(?) valve was out of spec. the throttle body was also replaced because it was sticking and because it came with the new IAC valve.
can anyone explain this to me?
J
Old Jan 8, 2002 | 04:49 PM
JasonT's Avatar
What dealer did you goto?
Old Jan 8, 2002 | 06:41 PM
Achance's Avatar
Coming to a city near you
Re: Throttle Body - Fixed, but I need an explanation!!
J
IAC is the Idle air controller and it must not of been giving the computer the proper info about the incoming air. And from my hybrid honda days I believe honda doesn't sell just the IAC for any car, I think you need to get the whole TB unit or a used IAC from a wreck. Or maybe that was a map sensor?? hell I forget
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
