Those looking for a cheap "cold air" intake try this.
Old Nov 5, 2005 | 12:16 PM
mrsteve's Avatar
This probably has been touched on before, as it is surely nothing ground breaking and this has been done before on tons of cars but I'll post anyways.
First, remove the stock resonator from the bottom of the stock intake. Then take dryer hose or similar material (those plastic gutters would work too). Route the dryer hose or gutter from the bottom of the stock intake to the lower portion of the grille behind the bumper. Top it off by replacing the stock air filter with a high-flow filter from Comptech or K&N (I believe they make one). It will sound nearly as loud as the AEM or Injen CAIs at WOT in the VTEC range and should pick up similar horsepower. This all can be done in about 30 minutes and for $50.
I had been driving around without the resonator for 2 weeks while I was waiting on my IceBox to come in. The stock intake without the resonator is MUCH louder than the IceBox at WOT.
Seems like there's a lot of new people around here who are on a budget. This will work great.
Kinda Kinda But who cares.
Old Nov 5, 2005 | 12:36 PM
blk2001tlon19s's Avatar
318whp/289wtq @ 6psi
good info steve.
Old Nov 5, 2005 | 12:59 PM
kwelling12's Avatar
very indeed
Old Nov 5, 2005 | 01:02 PM
mrsteve's Avatar
Originally Posted by kwelling12
very indeed
But it works
Old Nov 5, 2005 | 01:56 PM
SiGye's Avatar
1998 3.0
Is the resonator detatchable and retatchable? Or will I have to break it off? Should be detatchable but it's in there pretty good.
Old Nov 5, 2005 | 02:20 PM
Smitty's Avatar
Old Nov 5, 2005 | 03:26 PM
typeR's Avatar
if you wanted it to look more professional you could order the lower horn from comptech
Old Nov 5, 2005 | 03:35 PM
Smitty's Avatar
nobody can even see that part, but it does make the intake of air lower to the ground if you do not use the anything.
Old Nov 5, 2005 | 03:57 PM
SiGye's Avatar
1998 3.0
I've been thinking of going extremely and just taking out the resonator. If it sounds better why not? Plus, its free of charge.
Old Nov 5, 2005 | 04:22 PM
mrsteve's Avatar
Just taking out the resonator isn't ghetto. It'll change the sound at high rpms but you probably won't see anything in terms of power.
Old Nov 5, 2005 | 04:35 PM
SiGye's Avatar
1998 3.0
O ya i know i for sure won't get power. i guess it is less ghetto than using a hose for a CAI
Old Nov 5, 2005 | 09:56 PM
psychoRN's Avatar
RN are my initials...
but without the ghetto hose you still have a warm air intake. this is a great idea for those who have already removed the resonator, doesn't cost that much for a little test
Old Nov 6, 2005 | 08:40 AM
shill1234's Avatar
It ain't mine.
Dont you get some resonance at idle with the resonator removed?Only concerned about idle
Old Nov 6, 2005 | 09:18 AM
o1s's Avatar
o1s
not enough noise at idle to make a difference. it's the sucking noise from wot that makes the noise.
Old Nov 6, 2005 | 02:03 PM
Chopsie's Avatar
Beware of leakage
Interesting Idea Steve.
What I really thought was interesting was Ruf87's Icebox setup. He cut a hole in the splashguard and used a dryer hose type connector to come out of the hole. He uses this or tracking his TLS, and when not in use, he has it plugged with a tennis ball.
BTW I remember NBP CLS that had that same sig
Old Nov 6, 2005 | 03:16 PM
CL FWD SPEED's Avatar
What to do, what to think
smooth...as long as it works...btw...how come you sold your Blower steve?
Old Nov 6, 2005 | 04:28 PM
mrsteve's Avatar
Buying a house :w00t:
Old Nov 6, 2005 | 10:44 PM
ahhh.....of course I would choose a house over a comptech blower.....smooth bro
Old Nov 7, 2005 | 07:23 AM
fuzzy02CLS's Avatar
I had the resonator out & K&N filter in for a month now. I really don't think anything is louder.
I had an ice box on the old car.
For gains? Don't know. It's still too hot & humid in South FL to tell. We don't get cool air often.
Old Nov 7, 2005 | 02:00 PM
mrsteve's Avatar
It was DEFINITELY louder in my car.
Old Nov 7, 2005 | 05:41 PM
Louie11's Avatar
I've had this done on my car for 4 years now. I used 3" flex porting from JL and used a port horn on the end. I routed this out the bottom of the car for colder air and ram air. When the 03's came out I bought the inserts and replaced the running lights. Then I cut the back off the insert and made a fiber glass adapter to go from the insert to the tube. A even cleaner look and better ram air effect. This setup really makes the engine have a mean growl to it.
Old Nov 7, 2005 | 08:40 PM
peakpowermotoring's Avatar
Quick question, I have the resonator removed and a k&n installed would I gain power by installing a AEM cold air? Plus having a louder vtec wouldnt be too bad...Anyone?
Old Nov 7, 2005 | 09:39 PM
Lord Helmet's Avatar
I'm here in spirit...
My question is this:
With the resonator out, is there any chance of water coming up through the splash gaurd?
There are little holes and gaps everywhere down there for water to get in. Just curious.
Old Nov 7, 2005 | 11:44 PM
R J Poseidon 6's Avatar
~HondaF1~
Lightbulb
I should've done this a long time ago...
Old Nov 8, 2005 | 07:08 AM
fuzzy02CLS's Avatar
I don't see how. You would have to get into water up to the fender. It leaves a hole right under the stock air box. There's no way it would suck in enough water to do anything.
Old Nov 8, 2005 | 07:11 AM
fuzzy02CLS's Avatar
Most likely yes. The AEM & Ice Box are a complete system. How much is the question. The resonator is a restriction. It gets removed with any intake system. So that is some gain right there. How much on top of that depends on how well each complete intake system works.
Old Nov 8, 2005 | 11:15 AM
Viscous's Avatar
Steve,
What do you think of being ultra ghetto and hacking up the stock resonator so that it's no longer a closed "box" and so that it will allow air to be scooped in from the front/bottom? You could seal off that top portion where the stock hot air inlet is and only let air come in from underneath.
It probably wouldn't be too hard to pick up a cheap stock resonator box from someone here on the board and experiment with it, or use your own. Maybe I'll give it a try.. hah
Wonder how it would sound...
resonator photo
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
