is there a way to fix whistling
Is there a way to fix whistling sound of the Gates Belts/ UR Pulleys?
The Power steering UR pulley with Gates Belt is whistling at idle and low rpms.
I tried to loosen the belt, it did not help. I did tighten the belt and it did not help either.
If I put some soap on the belt the whistling sound goes away and then come back after the soap wears off.
Any fix?
Any fix?
I have used this special liquid that came in a small blue bottle (about the size of a '3 in 1 oil' bottle)called "belt dressing" or something like that ***used to see it in Kmart auto section*** It quited the belts on my '74 dodge dart, '82 LeMans, etc.... real nice I remember.
Now as I think more it was in a blue & brown can like size of wd-40 and said "belt dressing" on it. It might not have been in the automotive stores but possibly in the "hardware" store (before Homedepot...)http://www.valvoline.com/pages/produ...asp?product=32
http://alphasourceintl.com/cleandegr...intenance1.htm
If you need something that's wax-like, there's the stuff for bikes call WhiteLightening. It's a liquid wax for chains. The stuff works wonders for bikes.
http://www.cambriabike.com/tools/whi...tning_lube.htm
I just got this 2$ STP "belt dressing" 6-Oz Can.
It shut off the noise from the first application. Actually, I sprayed maybe 2-3 times on 2 parts of the belt. I did apply it on the AC clutch pulley too (just in case). I did apply it on the Sienna's belts too!
Somthing like this but made by STP:
Amazing results, now let us see how long it lasts. If it wears off, no problemo, 1-2s application would fix the noise again
SidhuSaaB
May 30, 2020 12:40 AM
