Suspension Question
Old Mar 8, 2004 | 10:51 AM
dfv3.2CL-S's Avatar
Suspension Question
After having the dealer install my CT springs I have been experiencing a clunking noise on the rear right shock area/pillar/rear deck. I have not taken the car back to the dealer because I am 2.5 hrs drive from the dealer. I was wondering if any one can help with specifics regarding parts that are normally losen and unbolted during the process of instaling the shocks and springs. I have gone under car and retighten the CT swaybars, but what else do I need too look for. Please help.
Also the stock springs had a black rubber guard on the bottom coils closes to the perch, should i have to place these on the CT springs for any reason.
Thanks for the info guys.
I have used the search but cant fing anything
Old Mar 8, 2004 | 10:56 AM
CLpower's Avatar
teh Senior Instigator
it may be the springs rubbing against each other. Did the springs come w/ a little rubber insulator to put around the spring?
Old Mar 8, 2004 | 02:51 PM
dfv3.2CL-S's Avatar
no, the springs did not have any rubber insulators.
Old Mar 8, 2004 | 02:55 PM
CLpower's Avatar
hmm, i'll wait for someone else to chime in then
Old Mar 8, 2004 | 02:56 PM
chef chris's Avatar
Homeless
Doesn't sound like they were Comptech springs then.
CT wraps the first few rows of springs with a black foam/rubber.
Where did they come from?
Old Mar 8, 2004 | 09:27 PM
dfv3.2CL-S's Avatar
Guys,
I purchased the spring on the blackmarket and they are CT springs. Also my dealer installed with no problems at all, but the only issue that I have is that I hear a clunk sound once in a while depending on road surface. My problem is not squeaking springs. I need to know what other parts of the suspension I could tigthen up to help resolved this annoying sound in the right rear. All other corners seem to be fine with no noise.
Old Mar 8, 2004 | 09:35 PM
KahRupt-CL-S03's Avatar
B A N N E D
Try to manually push the car down on the side where it sounds, maybe the shock is going bad. Also check to see if the shock is leaking, they usually leak when they go bad.
Old Mar 8, 2004 | 11:22 PM
pimpscls's Avatar
THE SILVER BULLET
that happened to me its the shocks, or the sway bar hitting the lower lining of your car it happened to me, take it to a dealer it cost me 82 dollars
BoricuaTL
Apr 8, 2016 01:08 PM
Heyzuez20
Oct 14, 2015 07:18 AM
datadr
Sep 12, 2015 09:12 PM
Nicho863
Sep 3, 2015 09:16 PM
