Supercharger and slight detonation..
CL-SEXY SIX (=
I finally weeded out all my problems with the supercharger phew..
The problem for the fuel cut was the positive cable from the alt. to the batt. was grounding out on the p/s pulley.
i soldered the ESM connections; voltage is at 2.91
boost is feeling great!
but i heard a slight detonation when i 1/2 throttled it next to the wall on the service road. Standard boost pulley... should my IMRC be disconnected?
should i get it tuned? i do have a emanage put to the side. But don't really want to spend an extra $300 for the harness and program if not necessary.
thanks guys!
thanks guys!
thanks guys!
thanks guys!
I don't know off hand, but you should do a search. There are a couple here that have ruined their engines with the supercharger. There is something that needs to be disconnected...
CL-SEXY SIX (=
hmmm, we have 93 here in NYC. I dunno, i thought the kit should have no problems out the tbox. But not everything is perfect all the time i guess. Just going to get the program and harness from Josh.
Thanks for your input guys.
Originally Posted by krisdlm
dunno about u but tunning is a must, at least in s.f. because 91 octane isn't cutting it and I experience detonation every now and then, just remember to let off
Tuning is not a must in any way shape or form.
CL-SEXY SIX (=
errr? so my car doesn't have to be tuned with the standard pulley?
Blown is Best
Lives On BOOST
Originally Posted by Allout
It shouldn't need it. I did get occasional slight detonation with the standard boost pulley when it was cold ambient air.
4drs just wanna have fun!
Tuning would help out a lot in terms of preventing this from happening.
Are you getting detonation primarily at IMRC and VTEC engagement? (3800rpm and 4800rpm give or take. On a boost graph you'll actually see boost climb a little bit at these point, like a spike.
Oh the voltage reading is also 2.93V not 2.91 so that'll help out with the detonation a little.
mrsteve is right check your static fuel pressure too, thats probably the most important thing you can do then the ESM.
CL-SEXY SIX (=
i was going to adjust the ESM but i got lazy...thought 2/10 of a voltage wouldnt make a difference. i heard the detonation prior to IMRC engaugement around 3800. Only when i get on it alittle. Werid. hmm...
im going to hook up my fuel pressure gauge once i get the right t-fitting
emailnatec
29
09-28-2018 04:27 PM
Joe Avesyan
09-29-2015 03:57 PM
xsilverhawkx
09-28-2015 06:51 PM
