Sunroof squeek
Sunroof squeek
I am having a small bit of trouble trying to convince my Acura service guy that the sunroof is NOT suppost to squeek when fully closed. When you open the sunshade and apply your hand directly in the center of the glass, then push up rapidly on the glass, you hear a squeeking sound. Now, this also happens when I am driving around. I believe it is the rubber seal against the actual car's sunroof frame area.
I remember a while back there was a TSB on this, telling the dealer to use a tape? Some members were even told to lubricate their opening of their roof?? (actually that's why my dealer suggested)
I would like to print out a copy of this TSB so it can get done correctly, not by using lube. Anyone got any links to a main TSB data base? or even better the actuall TSB for this problem?
Thanks!!
Thanks!!
Attention Sun Roofe Newbies ! Fock the tape, LUBE BABY, EVERY THREE MONTHS ! JUST ASK FOR THE LUBE AND SMILE, THEY KNOW ! IT'S BEEN SQEAKING EVERY SINCE I OWNED EM..........Right Acura Service ????????????????????? You think by NOW, they would RE-DESIGN that long over looked issue ! ?????!!!
So just remember "every three months, it's lube time" .....it just that simple !
Originally posted by acura_service
DON"T USE THE TAPE! the teflon tape sometimes comes off and leaves a sticky residue on the edge of the roof opening
have them lube it with the honda grease
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
