Sudden Breaking
Old Sep 24, 2012 | 05:45 PM
karanmc's Avatar
Sudden Breaking
Hello Guys,
I have a little question and a concern!!! I am driving down 495 about 60mpg and I feel a little shake in the body while breaking. I mean its not the entire body shaking as if something going to break down. So, i come home and jack it up to see if the tires are loose or anything but everything seems normal. Suggest!!!!
Old Sep 24, 2012 | 05:57 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Originally Posted by karanmc
Hello Guys,
Sounds Like a common case of warped rotors. My suggestion would be to get better aftermarket rotors and pads and make sure you bed them in correctly. I got mine from the sponsored sales group buy section from brakemotive. I've got about 10000 miles on mine with no problems and for 145$ you cant beat it.
Old Sep 24, 2012 | 05:59 PM
ParaSurfer1979's Avatar
Warped rotors. May be time to get them turned. They may not be so warped that you notice at 35mph and under but when the wheels are rotating very fast at 60mph+, it most def will get noticed.
Old Sep 24, 2012 | 06:51 PM
I agree however when I would get mine turned it would only last a few thousand miles before it started again
Old Sep 24, 2012 | 07:46 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
warped rotors.. do not get them machined.. you are just making the rotor thinner which is even worse at taking the heat.. i did it the first time and never again... just buy new rotors...
Old Sep 24, 2012 | 08:02 PM
yungone501's Avatar
J-series addict
"BRAKING"
Have a great day!
Old Sep 25, 2012 | 10:44 PM
aznboi2424's Avatar
Get new rotors. If the steering wheel is shaking then replace the fronts, this is the most common. If the whole car is shaking, replace the rears.
Old Sep 26, 2012 | 11:52 AM
Dspr_02's Avatar
Seeing as the answer has been provided,
DRIVING AT 60MPG!!!?!!!
Most of us are stuck driving at 60MPH... you lucky guy...
Old Sep 28, 2012 | 12:39 PM
karanmc's Avatar
Thanks everyone, is there a DIY on the F&R Brakes with pictures somewhere saved?
jdmaszfcuk
Oct 19, 2015 12:31 AM
lanechanger
Oct 13, 2015 10:56 AM
Skirmich
Oct 1, 2015 12:59 PM
hashbrown
Sep 29, 2015 12:13 PM
rboller
Sep 23, 2015 02:49 PM
