Sub causing rattles how to fix?
Old Dec 2, 2011 | 02:26 PM
harvthesecond's Avatar
Have any of you gone through the pain of fixing the rattles caused by a bit of bass in the trunk? Since its gotten colder out I've noticed my Alpine 12R has started making things in the rear window deck start rattling. What is the best way of finding the rattle and resolving it?
Old Dec 2, 2011 | 03:43 PM
exl124's Avatar
Dynamat the trunk. This will help reduce the vibration.
Old Dec 2, 2011 | 03:53 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
unfortunately bro there is no quick answer to solving the olll rattle. u basically hunt them down and either tighten what's making a noise, glue it, or put something around/between it to prevent it from rattling again.
i got on in my car i am just too lazy to hunt it down cause it's intermittent. but i'm sure one day it'll piss me off enough to pull off the back seat and shut that baby UP.
but it's just a PITA to be honest. I had about 6-7 bad one in my ford probe. it took me about a month to find all of them.. i know that sounds STUPID long, but some were burried and others only were bad in when it was super hot.. etc.
they were all tempermental.
good luck to u sir
Old Dec 2, 2011 | 07:23 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Check that you did not break the center mount for the trunk rods.
Mine broke and a few times a week I had too keep sliding the plastic piece that was left to the middle so the rods would not chatter together.
Also check your 3rd brake light housing.
You can try to tighten those screws from inside the trunk.
I removed mine completly because it was rattling.
Old Dec 2, 2011 | 07:42 PM
monkeybutt's Avatar
Second on the trunk rods rubbing/hitting. I used some dynamat type dampening material to keep the rods from contacting. I'm running a 15" sealed and have no more extraneous sounds.
Old Dec 2, 2011 | 08:11 PM
eneffex's Avatar
My problem is the 3rd brake light on spoiler, I've dynamatted the trunk, next thing to try is great stuff the hollow part in the wing itself. I think someone else here has tried it with good results.
Old Dec 2, 2011 | 11:56 PM
if the trunk tab breaks off just use self tap screws and it'd be fine i've done that on mine.
Old Dec 5, 2011 | 08:47 AM
Thanks everyone, I'll get to hunting starting with the trunk bars and 3rd brake light.
Old Dec 5, 2011 | 10:50 AM
fuzzy02CLS's Avatar
Same with my car.
Dynamat the trunk is good too. I just did my srt8's trunk this weekend. 50 sq feet of it.
Old Dec 6, 2011 | 09:29 AM
The rod mount was indeed broken off its mounting point. Is SOP just to drill it out and put some sheet metal screws through it?
Old Dec 6, 2011 | 10:50 AM
fuzzy02CLS's Avatar
That's what I heard, but I never could get it back into the location to do it. Too much resistance. I just left it.
Old Dec 6, 2011 | 02:29 PM
aznboi2424's Avatar
That's what i did. I put 4 screws in that sucker cause it came off again after I JB Welded it. If you close the trunk while your inside with a light and the drill, you can get the bracket to line up easier.
Old Dec 6, 2011 | 03:33 PM
This sounds exciting lol
Old Dec 6, 2011 | 04:23 PM
Wheeler07's Avatar
I put foam around mine and now im putting spray on sound killer to my side panels and rear deck and roof
Old Dec 6, 2011 | 07:13 PM
cu0ngsayz's Avatar
Since we are on this subject how do I remove the rear cover where the 3rd brake light and rear speaker?
Old Dec 6, 2011 | 08:53 PM
^ remove the seat back.
Old Dec 7, 2011 | 01:07 AM
99TLhot's Avatar
there no way you can fix it, i damming my hole trunk area and there no help at all well some help but you know still rattle , and if you have a spoiler there is even worce
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
spoiler900
Sep 23, 2015 04:41 PM
