Sub box keeps moving
Old Mar 15, 2004 | 04:36 PM
Artwork's Avatar
DP's for life
I was wondering if anyone has had the same issue where my sub box in the trunck keeps sliding around. Does anyone have a solution that is simple but effective. I do not want to put any holes in the box or the car (I will if I must , but do not want to), any ideas? Pictures would be great if you do have an idea or a solution to this problem.
Old Mar 15, 2004 | 04:38 PM
UNCTYPE-S's Avatar
Above n Beyond
how about silicone or that foam crap. might get messy if u dont do it right, but i have seen some people use that silicone foam stuff and the board around that.
Old Mar 15, 2004 | 05:56 PM
mrsteve's Avatar
Go to Home Depot and get the best Velcro they have. Cover the entire bottom of your box with it and then the trunk where your box sits. Voila no more sliding box. I did this in my Explorer before I had the CL-S worked great.
Old Mar 15, 2004 | 06:25 PM
bigman's Avatar
'Big Daddy Diggler'
get that stuff that you put under furnitur legs to keep it from moving around. this stuff is great for me.
Old Mar 15, 2004 | 06:41 PM
Linner's Avatar
best way is to flatten out your trunk with mdf and screw it down, but the easy solution is getting the industrial strength velco like said above
Old Mar 15, 2004 | 08:48 PM
Hobo's Avatar
Flap.
velcor that biatch
or just build ur box right :P
Old Mar 15, 2004 | 08:50 PM
SiGGy's Avatar
Moderator Alumnus
Originally posted by Hobo
velcor that biatch
ya, velcro is my thought too.
Old Mar 15, 2004 | 08:52 PM
Nicky Pass's Avatar
Fuct in the hed!
Screw it to the spare tire cover!
Old Mar 15, 2004 | 08:55 PM
Shawn S's Avatar
I use VELCRO on mine......Works great
Old Mar 15, 2004 | 08:56 PM
just a reader's Avatar
like other ppl sed...... go to home depot and get sum velcro. i believe its the industrial size one. dont even need to put it on the whole bottom of box, i only put 2 pieces on (left and right side) and the thing never moves, best solution imo cuz it aint permanent
Old Mar 15, 2004 | 09:05 PM
Shawn S's Avatar
And to clarify….You only need to use the “hook” side of the Velcro on the box.
It will grab onto the “fuzzy carpet” of the trunk really well.
I bought about 24” of the 1” wide strip variety and attached it strategically in a few spots to the box with a staple gun.
Shawn S
Old Mar 16, 2004 | 07:30 AM
scalbert's Avatar
And to think, I could have used velcro when I bolted mine in place with a custom bracket.
JK, velcro would not have worked for me as it would still have moved a little hitting the seat frame.
Old Mar 16, 2004 | 04:08 PM
Artwork's Avatar
DP's for life
Sounds good I will go and buy some tonight...Thanks for the suggestions
SidhuSaaB
May 30, 2020 12:40 AM
ITSJESTER
17
Dec 6, 2018 02:29 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
