Stone Headers ( & OBX headers) Installation and Dyno!!!
Finally, BlackmagiCL_S, myself, (had a chance to install the Stone Headers on my CLS and now his OBX haeders on his CLS...and have before and after dynos.
Let me first start with the installation of Stone headers. The installation did not go smoothly as expected
Unfortunately, we run into drilled-holes/engine studs alignmet problems.
I was so .. The front header, rear header had it is holes so tightly drilled, and not 100% aligned to the studs. Using the Gaskets as template, you may think that the drilled holes are Ok.. But they are not. I had to use a circular file and bore out those holes.. It was a very tedious labor. I was finally able to fit the front and then the rear was also misaligned. They can fit 50% at an angle but they do not fit if they are parallel to the engine block. After some more filing, We were able to fit the rear header. Similarly, the A-pipe needed a minor filing at its flange to the Catalic Converter. By 4:00 PM ... We were done with my CLS!! :o
Now, as for the before and after dyno. I had 4 pulls. The first was garbage as it was in open-loop mode and my CLS was not warmed up.. We warmed up my CLS, disabled the VSA and did another pull. This second one was Okay. After the installation of the stone headers, we did 2 more pulls... Both were good. I gained some 4WHP and 4 lbft all across the rpm as shown in this graph.
As you see, I included 3 graphs, Acutal HP (Uncorrected):
1) The last September's best pull with OBX headers 221 WHP, (The green graph)
2) Today's, OBX Headers pull, (The red graph)
3) Today's, Stone Headers pull, (The blue graph)
Now, the condition were as shown on this graph. ( Note how Today Cold weather resulted in a Correction factor of 0.92-0.93) !!! this means that the CLS engine would would make some 8.7% more HP than the standard conditions!!
Finally, correcting to SAE we get:
Note:, Although the I made some 17WHP more than last summer dyno, correcting using a 0.92 factor would result to a lower SAE WHP then last time best pull...
However, as you can see, the stone headers still outperformed the OBX headers by 3-4 WHP, 3-4 lbft!
And here is the A/F graphs along the (Actual HP):
Finally, one more observation. I dynoed this time on my Winter tires. A closer look to the dyno runs showed that this time runs are underdriven (slower than the Nittos on which the last time I dynoed) by 1.6%. Effectively, cutting the HP and Torque numbers for the this time runs by 1.6%
Here is the Actual HP with the Final Gear ratio expressed in MPH/RPM:
OBX headers Dyno on BlackmagicCL_S's (Stock 03 CLS- Auto):
BlackmagicCL_S dynoed some 202 WHP (STD) and then with the OBX headers he pulled 220 WHP (STD). He gained some 18-20 WHP (STD).
N.B.: Thanks for Bulldog for showing up too. I snaped his mug shot Just in case...
Originally posted by Zapata
1killercls,
About the same in terms of performance........howeover, Comptech doesn't offer DiY kit with their headers When they say bolt-on..........they mean bolt-on.
1killercls,
I bought comptech before and I would really do it again. Their quality is top-notch. Price is high but if you look at other cars and the amount of money people pay for performance products it's about the same as the Comptech. Take a look at what our BMW breathern is paying for an intake, headers, flywheel. Unless you buy a domestic and have MOPAR, etc., you really aren't going to have many choices. That being said......if you can deal with non-CARB issues and perhaps quality like holes not being big enough then STONE seems to be the way to go.
SOOOOOOOOOO......i'd buy comptech. It might take longer for me to get them but in the end I know that Comptech is Comptech
Price Should be very competitive. I need to be 100% sure that those Stone headers are 100% perfect and no single fitment probelm, before I do any Groupbuy!
I would guess $400 (shipped) for 10+ GB!
I once bought a set of OBX headers for $300-something shipped (whatever the lowest deal was, I forget now... I resold them for more later when they were OOS anyway), and I wouldn't pay any more for these than I would for the OBX. Okay, maybe $50 more. But honestly stick with stock exhaust manifolds or get Comptech headers.
Im confused? Isn't the green graph line the dyno from the OBX headers from before and the blue line is the stone headers? If so, then why in the 3rd to last graph is the green line making more hp than the blue line? I dunno, i am kinda drunk right now, maybe im just reading it wrong..........basically i guess im supposed to just know that the stone headers make more hp?
Simply, because of SAE correcting factor of 0.92 (for the blue line) versus 1.02 for the (green line)
This time runs were downgraded by 8% or some 17 WHP.
Last time runs were boosted by 2% or some 5 WHP.
Originally posted by Nashua_Night_Hawk
JRock,
So do you think that $400 for those headers (shipped) is a fair deal?
JRock,
Assuming a perfect fit that doesn't require re-drilling holes, yeah that's fair, IMHO.
I was pleased to gain almost 20hp with the OBX considering I had no intake so that was restricting flow coming into the engine. I only did one pull at the end since it was 6:20 at night and I was supposed to meet my fiance' and friends at 6:00 for a 6:30 movie. Fortunately the theater was just down the road and I made it there just before the previews started (saw Daredevil...cool flick). There is definitely an annoying resonance at around 2600rpm but it goes away +/- 100rpm. That kinda sux that there is any noice at all. There is also currently a low hum when idling. MAybe once everything settles in that might go away (?). Anyone else have this hum on their OBX? The exhaust tone is a little different, not better or worse. VTEC sings a little louder too. In any case, I haven't really ripped it up with the new headers but on the way home it definately felt a lot stronger. Hey, a 10% increase in hp is great any day. I am sure once I put the Icebox on then I will get more gains all around. But, 220whp with just headers is pretty nice I guess. I'll post my dyno graph a little later so don't go posting that "this thread is worthless without pics" thing!!!!
Oh, and thanks to Nashua for making this happen and thanks to Bulldog for showing up for a while. You are probably glad you didn't stick around. With the bolt alignment problems, it took 5+ hours (!!!) for the Stone install with dyno and 2 hours with dyno for the OBX. They just slid right on.
did you use the OBX gaskets or the stock ones? I am glad that you are enjoying the headers.. as for the resonance sound... I noted that once the car is warmed up, I would barely hear it!
Any word on when the stone headers may be released?
No... The Stone Headers made 4 WHP (SAE) and (4 lbft) more... Both headers were dynoed the same day. The OBX (run 004) netted 216 WHP (SAE) and the Stone Headers (run 006) netted 220 WHP (SAE).
I can guess that once my test-fitting notes has been taken into consideration, the mass production should start very soon. Next week or so, I will start taking GB Pre-orders. I need to get the fittment issues resolved first!
I will keep you all posted.
TL fitment?????
Will the group buy be for us TL folks too?????
Originally posted by motioneffects
If they align the holes right and can assure us of no other fitment problems, count me in.
Stay tuned
The Stone headers are port matched the OBX headers are not.
Here is the difference in pictures:
Obx Vs Stock Headers:
Here is the difference Gaskets Overlayed:
Stone Headers:
Stone Headers:
im new to the forum but i have been keeping up with the whole header thing after reding about some of the complaints with the obx headers making noise at 2600 rpm and looking at the pictures of the stock compared to the obx i can see why they make noise the gasket on the obx is clearly smaller than stock so think of it as a musical instrument you blow air over a reed it makes noisie same way on the gasket so if you were to port match the gasket to the head i think you could take care of the problem, and thats my two cents
The OBX gasket is a much heavier and thicker gasket than the stock one and is in fact larger than the stock gasket. Take a look at the pictures Nashua posted earlier in this thread.
I am sure that someone else has tried this, but I have emailed OBX about the resonance at 2500-2600rpm. I am curious what their answer will be. Perhaps wrapping the headers with some sort of teflon tape or heat-safe insulation might fix that problem? Anyhow, I'll post their reply (if I get one) to the forum.
Yup, the copper one is the stock one. It is REALLY thin which you can't really tell in the picture. The OBX (and the Stone) gaskets have a bit of squishable insulating material inbetween the perferated metal plates.
We didn't use any power tools because the guy at the shop was being kind of a pain in the arse and didn't want us to use his power tools without paying for the drill bits and stuff like that since he was already giving us a good deal on the install price. Long story. Better not to go there. The metal file worked eventually.
