static problems with new stereo
Old Jan 24, 2006 | 06:27 PM
cooperdh's Avatar
5th Gear
I recently purchased the JVC KD-AVXI receiver to replace the stock deck in my 01 CL-S. For those who are aren't familiar with it, it is deck with a 3" screen that plays DVD movies, etc. I also have an amp installed for my 10" sub.
Any way, when I play movies or music in it, I get a lot of humming background noise. I had a stereo person check it out and he seemed to think it was from the deck and not the amp since there was not humming noise when the volume is off.
Has anyone else had this problem with other decks? Could the problem be from the stock bose speakers? What can I do to get rid of it?
Help a brother out.
Old Jan 24, 2006 | 07:34 PM
phipark's Avatar
Not Asian
Try the A/V section.
Do you get the noise with the engine on and not off? Possible altenator whine. Maybe a ground loop problem.
Old Jan 24, 2006 | 08:22 PM
icy CL's Avatar
i may have to agree with you. does the sound get higher or louder as you accelarate or step on the gas? most likely it is from the alternator. make sure your ground is clean and run power wires away from rcas and speaker wires. you can also get a ground loop isolator.
Old Jan 25, 2006 | 09:54 AM
cooperdh's Avatar
5th Gear
The noise is also there when the engine is off. With the engine on, sometimes it gets louder or softer. Any suggestions on how to fix this?
Old Jan 25, 2006 | 09:57 AM
cooperdh's Avatar
5th Gear
I don't notice it getting louder when I accelerate. thanks for the heads up.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
