Starter Replacement
Old Sep 20, 2011 | 09:15 PM
silvervtec96's Avatar
Back to a MT!
Question Starter Replacement
Who has changed their starter here? Mine still starts, a bit slower, and has a clicking/metal sound during the cranking. One of my buddies said its probably the armature wearing out and not retracting quick enough so its binding a little with the fly wheel. I have one ordered starter and it looks straight forward, but the manual notes to reset the idle (forget the exact terminology), but it looks like disconnecting a bunch of grounds and pulling fuses. Did anyone do this procedure when changing your starter? I have disconnected my battery a few times and never did this before...
Old Sep 20, 2011 | 09:26 PM
StreetKA's Avatar
how many miles you got on the car ? i never heard about starter failure in our cars so i think it may be bad battery or bad ground check those before you go there...
Old Sep 20, 2011 | 09:31 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
easy swap.
just remove battery and tray to give your self room.
Their is only 2 wires and 2 bolts that will have to come off when removing the starter.
I removed mine the other day ,painted the main piece purple,the motor black and polished the long bolts because I was bored.
You will spend more time getting the battery and tray out than removal and installing the starter.
I did not do any idle re learn when changing the starter either so you will be fine with that.
Old Sep 20, 2011 | 09:33 PM
StreetKA's Avatar
^ but you put same one back one and he is getting new one
Old Sep 20, 2011 | 09:50 PM
Back to a MT!
I have about 160k on mine. I will check the grounds before I replace it. The battery is about a month old.
Old Sep 20, 2011 | 09:58 PM
I forgot the new one's have more bolts and wires
Old Sep 22, 2011 | 11:18 AM
Back to a MT!
I think I will try to jump it from my truck tomorrow to rule out the battery... After I check the connections though...
Old Sep 24, 2011 | 03:40 PM
Back to a MT!
So it appears to have been a lose wire to the solenoid... hopefully I can return the starter.
Old Sep 24, 2011 | 04:29 PM
StreetKA's Avatar
Told ya
Old Sep 24, 2011 | 06:04 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
lol i was gonna point my finger at the solenoid. almost always is the problem if it's starter related.
anyhoo glad to hear u got er fixed
Old Dec 30, 2011 | 12:46 PM
StypeCL's Avatar
HELP!!! I'm replacing my starter right now. I having problems with the 2nd (lower) mounting bolt. I just can't get the socket on the bolt head!! For you guys who have replaced your starter, did you go from under the car or under the hood? Did you use a socket extention?
Old Dec 30, 2011 | 01:05 PM
civicdrivr's Avatar
I havent replaced my starter, but Id imagine you'd need an extension.
Old Dec 30, 2011 | 01:27 PM
StypeCL's Avatar
I'm thinking I do need an extention. I watched a vid of a guy replacing his starter on his 03 v6 accord, and he did not need an extention.
I do though!!!!! I only have 2'' ext.!! (that sounds sad)
Looks like I'm chillin till the 6'' extention ferry visits me!!
Thx
Old Dec 30, 2011 | 03:48 PM
StypeCL's Avatar
The extention ferry stopped by, all done!!
You definataly need a 6'' extention when swapping out the starter.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
lovic87
Sep 15, 2015 06:07 PM
Sep 14, 2015 10:09 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
dlknight
Sep 3, 2015 07:54 PM
