Started on some in home porting
Old 05-19-2015, 10:36 AM
  #1681
3.7L Nitrous Breathing CL
richardparker's Avatar
Originally Posted by gnuts
is the 6speed harder to launch consistently though?
A little, that's why I want a launch control.
Without the launch control I have to use my foot to control the rpms while preloading the drive train with the ebrake.
3 out of my 4 runs were pretty consistent.
1 was crappy because I spun the tires all of first.
I consistently pull 1.8 60fts 8.4 @86
Originally Posted by brian6speed
I find the manual easy to launch, but you need to get use to it.
Weight removal might not help that much because main issue is traction.
The manual is easy to launch If you have the time. Only thing is if you don't have time to preloaded the drivetrain to your desired rpms and the lights start moving then you will be inconsistent.
The launch control will actually give you a little more time to focus without having to look at the dash watching the rpms before the lights start moving.
Weight could be a small issue but I'm thinking its in the valve adjustment or the clutch not being broken in yet.
Probably only have just over 200 miles on it.
Originally Posted by AnthraciteTypeS
Were your traps higher with the 6 speed though?
Everything was better with the auto so far. It had more mph for sure but I do think the 6 speed will run better after some tweaking and more parts.
Old 05-19-2015, 10:54 AM
  #1682
6mt swapped..smart
AnthraciteTypeS's Avatar
The manual definitely gains its advantage up top after the autos 1st and 2nd gears. I bet you'd see a bigger difference in a 1/4 as opposed to 1/8 where the manual really has a chance to stretch its better gearing.
When my old auto shifted into 4th, it literally fell out of vtec and flat on its face..probably right around the beams in the 1/4
Old 05-19-2015, 06:12 PM
  #1683
I just got done adjusting my valves. All the exhaust valves were a touch tight for my liking. So I backed them off a touch to a looser 12
Mostly every intake valve was perfect.
Thinking about removing the tiny manifold horns and shaping the body of the manifold to be the shape of the horns.
I want to do it for it to act like shorter runners and increase the manifold volume at the same time.
Only thing if it does not perform better I just ruined my manifold.
Thoughts on that ?
Old 05-20-2015, 11:21 AM
  #1684
Well, the manifold is getting more port work done right now.
I think what I'm doing is going to work out good.
Runners are definitely going to be shorter in lenth and the way I'm doing them they will have huge openings now that will be tapered into the runners.
The manifold will have more volume and lose a little more weight.
I'm also going to try to take out more aluminum internally to gain more volume as well.
Pics up tonight ?
Old 05-20-2015, 01:17 PM
  #1685
Lone Wolf
brian6speed's Avatar
Any chance of a before and after dyno? Are you doing it as a P2R plenum alternative to allow more volume?
Could end up being a lot of work for nothing, but can't say for sure till you try it.
Custom exhaust seems to be best place to spend money and make gains. That seems like more of a restriction than intake. 1 7/8" primaries to 2.5" DP to 3" exhaust.
Old 05-20-2015, 04:25 PM
  #1686
No dynos ever yet.
Yeah a cant find any plenums so I'm trying to move the power a little higher in the band (if possible).
Since I'll be back to the nitrous soon I wont mind if it loose a little low end.
The nitrous will make up for whatever its slacking.
I'm only running the coated header and the xlr8 cat ,and that's it.
Maybe I should put a exhaust on I think it ran faster with it.
First 3 holes on the manifold almost done, I've been busy to put in the work to get it done.
Old 05-20-2015, 10:54 PM
  #1687
Before and Ruffed
Without the horns it opens up the manifold quite a bit.
Old 05-21-2015, 08:57 PM
  #1688
No finished pics ,just finished it and got it all back together and just took it for a short ride down the street just now.
So I loosened the exhaust valves, worked the manifold,and put new plugs in.
At start up the car seamed to idle easier and sounded smoother.
Car seamed faster 1st and 2nd thats about all i got going down my street.
But in 2nd I hit the gas and lite the tires all of 2nd easy.
Cant wait till sunday,I think the car is faster.
Im betting loosing the valves did it.
Old 05-22-2015, 06:45 AM
  #1689
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
I would say with 99.9% certainty you dont have any mechanical issues. The issue/reason your numbers are lower are most likely the gearing, traction, and launch. While you may think its a consistent launch or a good one i would bet there is room for improvement. I have been driving stick pretty much my whole life and can say very few launches are consistent or optimal. There is a very fine line you have to run of wheel spin on launch without full blown spinning. Especially with street tires. I would also stop running 1/8 and start running 1/4. Especially with the manual gearing and your power and weight. It would give you a better number to compare to how you are doing with the rest
Old 05-22-2015, 08:13 AM
  #1690
Lone Wolf
^ +1.
Was going to mention looking at changing final drive, but just saw you already posted in that thread. Maybe there is an accord or some other honda/acura you can get one from, without having to pay TB Motorworx prices.
Not sure if the 6 speed will live up to your expectations as a drag only car tranny.
Old 05-22-2015, 09:10 AM
  #1691
fsttyms1's Avatar
^ +1.
(it is lighter which will help the car, and far more reliable but will be harder to get the same time, time after time with the launch
Autos are far better for consistency and are typically now days faster. The Manual can be quick if launched correctly and shifted quickly without mis-shifts. It will also come into its stride more in the 1/4 than the 1/8
Old 05-22-2015, 10:20 AM
  #1692
Dharma Member
ahxChun's Avatar
The TB fd is an OEM one redrill by liberty. Cheapest way
Old 05-22-2015, 11:15 AM
  #1693
Well, Gear set is on the way.
Lets see what it will do.
Old 05-22-2015, 12:54 PM
  #1694
03 tls nc's Avatar
Go big or go home! AWESOME!!
Gonna try to make it down to Shady Side this year since I got the 3.5 in.
Old 05-22-2015, 01:25 PM
  #1695
6mt swapped..smart
Details, which gears??
Old 05-22-2015, 01:41 PM
  #1696
Trying.
Yeah man get it down to the track ,I would like to run a similar car.
Right now I'm only on the motor.
Did you go manual trans yet ?
Final Drive - TB Motorworx of San DiegoTB Motorworx of San Diego
Old 05-24-2015, 12:06 AM
  #1697
A little VIDEO messing around in my cadillac .
http://vid899.photobucket.com/albums...psz6mq5cft.mp4
No problem spinning 3rd.
Old 05-28-2015, 04:53 PM
  #1698
O yeah, gear set arrived early.
Cant wait to feel some 3rd gear.
Old 05-28-2015, 06:28 PM
  #1699
fsttyms1's Avatar
Old 05-29-2015, 10:11 AM
  #1700
Scottyknows007's Avatar
Name:  power-jeremy-clarkson-top-gear-power-demotivational-posters-1371363896_zps9aa1f941.jpg
Old 05-29-2015, 10:36 AM
  #1701
I think sonick said the gear upgrade should feel like a 16-18% gain in torque every gear or something like that.
Just lined up a shop about 25 minutes from me for $300 to install it.
Now I have to squeeze time to get the engine and trans out again.
Old 06-02-2015, 10:18 AM
  #1702
Getting it in today.
I got the engine and trans ready to come out by 11am,Just waiting for a friend with a lift.
I'm getting good at pulling these things I don't even think I put 3hrs into it to have it ready to pull out.
Hopefully the trans will be at the shop and back in the car this weekend.
Old 06-03-2015, 09:39 AM
  #1703
Trans is at the shop getting the FD installed!
Old 06-05-2015, 06:15 PM
  #1704
Trans is back,just waiting on the fresh clutch stuff!
Old 06-06-2015, 01:59 PM
  #1705
decided not to run front and rear torque dampers because I did not want to add weight.
Those dampers are pretty heavy.
Instead I ordered Innovative 95a extreme engine mounts today.
Old 06-08-2015, 05:19 PM
  #1706
Got my new flywheel. This one is way tighter than the other one I had.
The other one I had was looser than this one right out the box and is kinda sloppy now.
Is it normal for the flywheels to become sloppy or should they stay tight ?
Old 06-11-2015, 12:42 PM
  #1707
Got my clutch master fx400 for OEM flywheel.
Disappointed by the looks.
First off, I was unaware they were including a sac PP with the kit.
2nd ,the throwout bearing in the kit looks like the same garbage being sold on ebay.
And 3rd, the p2r hub on the disc looked more beefier.
2 things I did like were:
The PP looks like it was resurfaced from the get go and feels like it would have more bite before breaking in.
And the fingers on the PP are modified at least twice as high as the OEM pressure plate .
It should hold better but,we will see.
Old 06-12-2015, 09:15 AM
  #1708
Old 06-13-2015, 09:56 PM
  #1709
Fresh flywheel,disc and pressure plate installed.
Old 06-26-2015, 12:22 AM
  #1710
Installed the 95a mounts today.
Old 07-09-2015, 12:18 PM
  #1711
Received 1,855 Likes on 1,496 Posts
Hey, RP, how is the new fx400 clutch; PP; FW; motor mounts and final drive gear set combo working out for your 6 speed beast?
Old 07-13-2015, 03:07 PM
  #1712
With that list of parts I wonder why I haven't started it yet.
I've really been busy.
All is in besides axles,knuckles and wheels.
I only have 2 cars left in my way of working on my car.
Old 07-13-2015, 03:27 PM
  #1713
^In for updates when you get to it. Very interested in how the new drive gear set performs for you within a CL6speed tranny.
Old 07-31-2015, 06:35 PM
  #1714
I finshed the car and drove it very littlebut I think its going to be faster.
My car loves being over 3k rpms and from start up it kills me to stay under 3k rpms.
I also don't think there was much added vibrations from 75a to 95a mounts.
Shifts also feel a little more tighter since the mounts.
Old 09-22-2015, 09:44 PM
  #1715
Did a little more aggressive driving compared to babying it.
Letting clutch out chirps the or spins the tires so easy.
Like not even trying.
Also did some quicker shifting and taking the rpms to 4-4.5k with maybe a 1/4-1/3 throttle and the car pulls strong,really strong.
I can only imagine how its going to be full throttle.
By driving today I would say it will easily spin 4th on it and perhaps into 5th.
If you want a faster car this gear set will definitely be the mod you should do,no dought.
zeta (09-23-2015)
Old 09-22-2015, 10:48 PM
  #1716
teh CL's Avatar
That just gets me excited
Old 09-24-2015, 06:26 AM
  #1717
03 acura cl type s
rush's Avatar
did a little more aggressive driving compared to babying it.
By driving today i would say it will easily spin 4th on it and perhaps into 5th.
any vids?
Old 09-24-2015, 09:52 AM
  #1718
No vids yet.
Let me get more time on the clutch first ,I probably only got 150 miles on it.
I don't want a low rpm vid and I don't want to fry the clutch setup (again) being too impatient.
Maybe be the end of next month. I don't drive it very much.
Before my track closes for the season I'm going to get the facts.
If theirs improvements the slips will show them.
Old 09-24-2015, 10:02 AM
  #1719
3.5 psi
gnuts's Avatar
nice! I love that we'll get to see before/after slips for the final gear.
mada51589
05-03-2022 08:54 PM
obert
12-14-2015 11:36 PM
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
jordanboi
09-05-2015 01:33 AM
Quick Reply: Started on some in home porting
