SRS light.....
Old Apr 23, 2012 | 03:05 PM
Mr3.2S's Avatar
Rollin the SRT8 or my CLS
SRS light.....
I already read about this in the owners manual, it could be one of a few things. So my question is, have any of you had this occur, if so, what was the problem, and was it costly? Also is this common?
Old Apr 23, 2012 | 03:43 PM
Karanx7's Avatar
Unregistered Member
Depends. Has anyone been messing with the electronics in your car recently?
Old Apr 23, 2012 | 04:01 PM
Mr3.2S's Avatar
Just had the tranny replaced.
swoosh's Avatar
takin care of Business in
why the SRS will come on:
1> blown fuse
2> if you tap any electrical accessory in that fuse (radar detector/LED lights/etc)
if either of those scenarios are not true then i suggest unplugging the battery and resetting your ECU.....i think that light should go off....
PS: Before you unplug the battery make sure you have your Radio/Navi codes handy !!!
Old Apr 23, 2012 | 04:43 PM
Karanx7's Avatar
Unregistered Member
No, you have to do the SRS reset procedure. You can Google it.
If that doesn't work, then you have an actual SRS problem.
Old Apr 23, 2012 | 05:07 PM
ivan06106's Avatar
I got the same problem :/
Old Apr 23, 2012 | 05:24 PM
AustinTaper's Avatar
Registered Member
There is a factory recall on this issue...it is related to the seat belt or something. Check the forum above for troubleshooting...there are countless threads (search...). Most dealers will repair it free of charge if it meets the recall criteria. If not, it could be one of the issues noted above.
Old Apr 23, 2012 | 05:42 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
yea i had this issue and just did the reset and it was all fine and dandy..
Old Apr 23, 2012 | 06:22 PM
Squag27's Avatar
I just did the SRS reset on my CL, it takes about 30 seconds if you have a paper clip or a pair of wires. And thanks for the idea, that light's been driving me nuts for months!
Old Apr 23, 2012 | 06:37 PM
Mr3.2S's Avatar
Thanks for the info all! Much appreciated!
Old Apr 24, 2012 | 08:08 AM
fuzzy02CLS's Avatar
Dedicated thread......
https://acurazine.com/forums/2g-cl-problems-fixes-70/srs-indicator-light-warranty-extension-478199/
mugen_kid
Nov 13, 2015 10:38 PM
brboy
Oct 5, 2015 11:34 AM
terrancems
Aug 30, 2015 08:08 PM
oonowindoo
Nov 8, 2001 01:09 AM
