Squeaking Windows Problem
Old Apr 7, 2002 | 05:05 PM
some1's Avatar
You know him right?
When I roll my windows down, the window rubber on the outside that goes agains the window folds over and down into the window track. It makes an annoying squeaking sound. Anyone know how to fix this?
Old Apr 7, 2002 | 05:20 PM
Marc S's Avatar
I have a similar problem with my CL, whenever i roll down my window it "hesitates" in a way. It doesnt roll down gently like it should. it will go down but shakes along the way. Any ideas?
Old Apr 7, 2002 | 05:22 PM
SiGGy's Avatar
Moderator Alumnus
ugh, mine do both of these things...
sometimes it rattles and shakes, sometimes it doesnt. But it always squeaks...
I'd also appreciate any ideas to help, as the dealership didn't really do much...
Old Apr 7, 2002 | 06:44 PM
23wt's Avatar
Mugen Racing Team
My windows 'sometimes' does that when it rains.... That happens to my friends civic as well, but also only when it rains. But his rattles worst.
Old Apr 7, 2002 | 06:52 PM
riceboy's Avatar
Darth Tator
mine was okay until i got my windows tinted.
but only my driver's side window squeeks
Old Apr 7, 2002 | 06:56 PM
Marc S's Avatar
I guess that could be my problem also. Not to much we can do if thats the case
Old Apr 7, 2002 | 07:29 PM
23wt's Avatar
Mugen Racing Team
Yeah me too, i didn't notice that until i got my windows tinted. That also occured after my friend got his civic windows tinted.
Old Apr 8, 2002 | 12:03 AM
Red Rider's Avatar
Subie Dubie
I've had the same problem on the drivers side, but mine aren't tinted.
Old Apr 8, 2002 | 02:04 PM
some1's Avatar
You know him right?
Ya I have tinted windows, but the squeaking didn't start then. It actually started after the dealership removed my passenger door panel to fix the door lock actuator. But now both doors make the squeaking sound, so I'm not too sure.
I don't see how tinted could do it. I'm pretty sure mine squeaks because the rubber that rubs on the outside of the windows sticks to the windows and folds in and down into the door panel. Then it stays folded inside until I put the window back up. ???
Old Apr 8, 2002 | 02:18 PM
dmcconnell's Avatar
Re: Squeaking Windows Problem
I had a similar problem with my '94 Prelude VTEC. My driver's window was actually completely stuck in a partially open position. I spoke to the service representative, he said, "Just spray a little silicone spray in the rubber channels that guide the window". A very simple fix for a very common problem. Just turned 40K miles on the CLS, but I haven't heard any squealing yet. Hope that helps everyone!
Old Apr 8, 2002 | 10:02 PM
some1's Avatar
You know him right?
Re: Re: Squeaking Windows Problem
I have never heard of silicon spray? When you "rubber channels that guide the window", do you mean the rubber that is touching the window if you look at it from the outside? What would this spray do? Where can I buy some (any hardware store??)
Old Apr 8, 2002 | 10:55 PM
WebToker's Avatar
Re: Re: Re: Squeaking Windows Problem
My windows don't squeak but my drivers side window does rattle. Its like the glass is hitting something metal. It has been getting worse over the last 6 months. It only happens when I drive over the lane bumps on a freeway or sharp bumps on the streets. Anyone else had this problem? I figured I would just take it to the dealer when I had my alignment done and have them take a look at it.
Old Apr 9, 2002 | 07:31 AM
dmcconnell's Avatar
No, I am refering to the guide channels on the sides of the window frame that guide the glass up & down. The spray would provide lubrication. One can buy it at any hardware store. WD-40 is a popular name brand, but any silicone spray will do.
Old Apr 9, 2002 | 08:15 AM
some1's Avatar
You know him right?
oh Thanks...I didn't even realize what you meant by silicon spray. I know what WD-40 is. I'll try that...Come to think of it, what would be the easiest way to spray the channels and to get the whole thing?
Old Apr 9, 2002 | 08:45 AM
WebToker's Avatar
Take the door panel off.
Old Apr 9, 2002 | 10:48 AM
dmcconnell's Avatar
TOTALLY UNNECESSARY !!
Old Apr 9, 2002 | 11:06 AM
WebToker's Avatar
OK!
Old Apr 9, 2002 | 01:55 PM
some1's Avatar
You know him right?
Thanks, but I was hoping you had an easier way to do it!!!
Old Apr 9, 2002 | 01:56 PM
some1's Avatar
You know him right?
Any help dmcconnell???
Old Apr 10, 2002 | 09:23 AM
dmcconnell's Avatar
I am not sure what you mean? If you are looking for an easier way than rolling down the window and spraying the window channel with silicone spray, I can't help you.
Old Apr 10, 2002 | 09:33 AM
Tommy H's Avatar
Re: Re: Re: Re: Squeaking Windows Problem
WD-40 is petroleum based, actually. I think 3M has a silicone lubricant. You'll see it at any hardware store, probably about the same place you'd find the WD-40. Word of warning, you might need to clean your windows a few times to clean up any excess spray - a bit of that on your window streaks real bad...
kmawani
Feb 8, 2023 05:09 AM
jblessing
Aug 8, 2018 09:43 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
2012wagon
Sep 29, 2015 04:21 PM
njresendez
Sep 21, 2015 11:23 AM
