springs / shocks
Old Apr 30, 2003 | 08:53 AM
foe's Avatar
foe
springs / shocks
If I get springs do you I need to get new shocks as well?
Old Apr 30, 2003 | 09:07 AM
skinsfan202's Avatar
do you need them? no
will they improve your handling?yes
My cl has 71K and the factory shocks went bad at 60k so I replaced them with tokico adjustables.
It does handle a lot better.
If I were you I'd go all out and get the sway bars and bigger wheels to really improve your handling that's what I did.
But if you are just doing it for looks all you need are springs.
Old Apr 30, 2003 | 09:11 AM
6speedS's Avatar
Quicksilver
i would say yes based on my experience. I got Eibach pro-kit springs on my car with the factory shocks at around 7K miles, and at around 19K, there are shot! So now, i'm getting Tokico's this week.
Old Apr 30, 2003 | 09:17 AM
beerknurd's Avatar
Busy Living
which shock wears out first? I can't imagine it being the rear. I would highly recommend swapping the front as that is the most labor intensive spring/shock to replace. the rears are much easier to swap then the fronts.
Old Apr 30, 2003 | 12:24 PM
peiqinglong's Avatar
If you get Comptech springs...aftermarket shocks aren't needed. If you get stiffer springs like Eibach and H&R...you'll need springs real soon. Think of it this way, the stiffer the spring, the sooner you need shocks.
Old Apr 30, 2003 | 12:35 PM
foe's Avatar
foe
Btu getting comptech shocks are recomended when getting comptech springs right
Old Apr 30, 2003 | 01:19 PM
CO-CL-S's Avatar
They are by CompTech, I don't know about others though..
Old May 1, 2003 | 12:36 AM
Nice to have...but not necessary.
Old May 1, 2003 | 12:39 AM
ktgumbo's Avatar
Balla on a Budget
Even if the car has like 50K on the odom? Are these covered by the Acura warrenty if the car is not lowered?
Old May 1, 2003 | 11:17 AM
Well if the car has 50k on it, then it might be beneficial to switch out the shocks. Shocks I do not believe are covered by warranty because they are subjected to normal wear clause.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
