Spring help
Old Aug 4, 2003 | 01:08 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
Spring help
I know... I know..... SEARCH. BUt everyone that has springs is never spacific on what spring they have. also they dont give to many pics. Anyway all I want to know is.....
1) I am getting 19's and want about 1 finger wheel gap.
2)I want the ride quality to be like stock and I dont want to have to put after market cambers on......... PLease post pics of your drop if you have any thanks.
Old Aug 4, 2003 | 02:31 PM
italiaCLs's Avatar
Bump<>^^^
Old Aug 4, 2003 | 02:52 PM
Silverbulit40's Avatar
Enjoy the Ride
COMPTECH
Old Aug 4, 2003 | 02:57 PM
JakeCL's Avatar
1 finger gap with comptech... yea right
Old Aug 4, 2003 | 03:15 PM
italiaCLs's Avatar
so whick one? H & R sport....... I want to get these but am worried about rubbing.... Also worried about ride quality. The H & R OE might be a better choice.... AS long as they are lower then the comptechs.. right.?????
Old Aug 4, 2003 | 05:11 PM
CT3.2's Avatar
The CL Crazy
H & R sport would be your best bet to get the 1 1/2 finger gap it wont be 1 finger no way, but to be frank to have it to the height you're looking for with the best stock ride you should get Teins. There's no other option. Ride quality wont be like stock with 19 and H-R springs. I have 18 with comptech and it's a little rough and are supose to have the best stock feel on the market. I have a 2-finger gap in front and a 2 1/2 in back.
Old Aug 4, 2003 | 05:20 PM
italiaCLs's Avatar
what about if I get Konis W/ the H & R sport springs..... will that make it have a much better ride quality?
Old Aug 4, 2003 | 05:34 PM
italiaCLs's Avatar
Or what about going with H & R OE sport springs. The only thing is are they close to stock and are they more of a drop then the comptechs?? thanks for all replies!!!!!!
Old Aug 4, 2003 | 09:57 PM
Roleez's Avatar
When I first got my Comptechs + Koni/Neuspeed yellows (5 adjustable spring perch positions) installed, the perch clip was set at the 4th position (2nd from bottom) giving my CL the "1 finger" gap you're describing (0.8" gap). You will NOT get a stock ride with the car sitting that low. Even w/ the shocks at their softest setting, the ride was horribly bouncy, plus all four corners cambered big-time. Even turning the stiffness up a tad (or more) won't tune the ride quality to that cushy stock ride you like.
Disappointed, I had the clips raised two notches upwards (to reposition the clips, the whole suspension assembly needs to be removed and reassembled) and lo and behold, the stock ride returned. Gaps measure 1.75" at all fours. Oh, and at this ride height, I still needed a camber kit... but only at the rear. Why? The rears were at the alignment limit and after its first alignment, the rears re-cambered 3 days later. So I had a Comptech rear camber kit installed. Now the car rides/tracks perfectly.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
CarlosILX13
ILX Performance Parts & Modifications
14
Jul 11, 2016 11:07 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
