Sport Shifter Question??
WHEN I HAVE MY CAR IN THE SPORT SHIFTER AND LET SAY IAM IN 5th GEAR, SOMETIMES WHEN I HIT IT SO THAT IT SHIFT DOWN IT DOESNT DO IT AND I HAVE TO HIT AGAING....IS THAT NORMAL???
AND ALSO IF IM IN 5th AND I HIT TWICE TO GO DOWN TO 3rd IT DOSENT DO IT, IT WILL ONLY GO TO 4th AND I HAVE TO HIT IT AGIAN SO THAT IT WOULD GO DOWN TO 3rd.... IS THAT NORMAL TOO???...
Cajun Gumbo Man
No wonder these transmissions are going bad !
Everything you're explaining sounds normal. You have to remember that there's about a half to full second delay on the SS, so from the time you tap it to down shift and it downshifts could take up to a full second. That being said, hitting it twice will actually only result in a one gear downshift.
As for it not down/upshifting, it could also be related to your RPMs. I know there's been times I've been cruising around 2200 RPM in 4th and I try to go to 5th and it won't let me. Once I speed up a little it's fine. I've never heard of it not shifting while you're accelerating. There's no clutch, so you should never need to lift your foot off the gas to shift......
Cajun Gumbo Man
Can you say INTERNET SAVY ???????????????????
Received 7,451 Likes
doesn't anyone heel and toe around here? BMW saw the wisdom (SMG) of matching revs (as did Ferrari) on their autoshift programs which just reinforces my belief that you should do it as well. I blip the throttle when downshifting and do it according to what gear I am going into. That is, if from 4th to 3rd, I do not blip the accelerator as hard as I do from 3rd to 2nd. try it, you'll like it!!
rockyboy
09-19-2015 12:09 PM
09-17-2015 09:01 PM
