Something is wrong with this Dyno!
Old May 20, 2002 | 10:20 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Looking at this dyno chart, UR AV6 pullies, the torque and HP curves crosses at different rpm. The before curve crosses at > 5200 rpm and after curve < 5000 rpms
It seems wrong for me
Old May 20, 2002 | 11:44 AM
CLpower's Avatar
teh Senior Instigator
sounds BS to me, all cars crossover at 5252 RPM
they'll always cross @ 5252 RPM, 1 HP is equivalent of 33,000 ft lbs of work per minute, and at 5252 RPM, 1 ft lb is equal to 33,000 ft lbs of work per minute, so they equal out. just like at 2,626 the HP is half the torque, or at 7,878 the HP will be 1.5 times the torque, or at 10,504 the HP will be double the torque. and no matter what the peak torque RPM is, its always gonna cross with the HP @ 5252 because HP is calculated, and at 5252 1 hp = 1 TQ, or however much power you make.
Old May 20, 2002 | 12:18 PM
chikai's Avatar
trying to get a lil V-I
ghander....
thanks for that info, I guess we learn something new everyday.
Then I guess my dyno was fairly accurate.
Old May 20, 2002 | 12:30 PM
NOLACLS's Avatar
you only dynoed 186 hp...I thought everyone else was getting like 200 or so???
Old May 20, 2002 | 02:37 PM
Styles__69's Avatar
most people who get dynoed get at the most 196hp's stock
its sad..
but your dynos look strangely low
Old May 20, 2002 | 02:54 PM
chikai's Avatar
yeah, I was a lil' surprised at how low my dyno was too...
Then i heard that Mustang Dynos were typically lower on average than others (ie: DynoJet).
Supposedly Mustangs Dynos are more accurate because it uses two barrels vs. just one for the tires to rest on.
Old May 20, 2002 | 03:20 PM
liquid_x's Avatar
License: numb nuts
Old May 20, 2002 | 03:40 PM
frank828's Avatar
just to let you know, that dyno is not altered in any way. I know the guy (viper aka Samir) from the accordv6 forums.
Old May 20, 2002 | 03:43 PM
Happy CL-S Pilot
I will be ordering a UR pulley (Polished) anyways from the V6accord group buy, it would cost $275 plus shipping. I estimate a $75 is enough to get it installed by a Honda/Acura Master tech!
Old May 20, 2002 | 03:50 PM
CLpower's Avatar
then why doesn't it crossover at 5252?
Old May 20, 2002 | 04:05 PM
tankmonkey's Avatar
6 speed...
Re: Something is wrong with this Dyno!
the graphs are fine.
the lines don't cross because the scales are different for hp (90-180 on the left) and torque (70-190 on the right) on this graph.
the hp still equals the torque at 5252 rpm for both runs, as would be expected.
Old May 20, 2002 | 04:08 PM
tankmonkey's Avatar
6 speed...
the hp and torque curves are plotted on different scales. they'll only cross (on a graph) at 5252 if they are plotted on the same scale.
Old May 20, 2002 | 04:09 PM
Happy CL-S Pilot
That could be it. Good analysis!
Old May 20, 2002 | 04:13 PM
CLpower's Avatar
that would make sense
right after i make this post
http://www.v6accord.com/forums/showt...2356#post69636
Old May 20, 2002 | 04:18 PM
Happy CL-S Pilot
However, I do still believe that both curves should cross at the same rpms regardless if it was 5225 rpm or not.
Anyother thought?
Old May 20, 2002 | 04:20 PM
KavexTrax's Avatar
Is your actuator functioning properly??
Old May 20, 2002 | 04:43 PM
Pull_T's Avatar
Anyother thought?
What tank is stating is right...the graph is just scaled differently for torque and horsepower.
Old May 20, 2002 | 07:21 PM
chikai's Avatar
Huh...I hope it is. I dyno-ed the car w/ 4500 miles on it, and I also feel that extra "boost" when I step on the gas harder in low rpms and in the same gear.
acuratl26
Apr 23, 2020 07:30 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
rangomango
California
Sep 24, 2015 05:47 PM
Hines57
Sep 24, 2015 01:58 PM
