Somebody help....
proffesion...axle breaker
Somebody help....
alright im trying to remove the door wood trim, i have the door off and was going at it....and my dremel broke....and i am all out of ideas on how to remove them damn rivet things on the back....anybody have ideas or what they used before?....and no im not buying a new dremel.
Look at your owners manual for the dremel.. There are plastic screws on the side that allow the brushes to be taken out. If they have warn too thin, then you can buy some new brushes and your back in business...
<--- own 2 dremels.... one w/ bad bearings (I had hoped it was just the brushes), and a new one to replace it...
im going to tackle that obstacle once it stops freakin raining and i can paint them....then ill let you know what i come up with....but maybe some of the members who have done this can share their info..?
Received 1,080 Likes
You need to be very careful removing the trim.
I used an exacto knife and just sliced the top of the plastic rivet off. I then used small sheetmetal screws to hold it back on.
I'm here in spirit...
Originally Posted by Stealth CL
So far...center trim is done, along wit hthe shift gate
and gutted...thats how we roll
I used quick setting epoxy to re-attach my trim to the door panels. It worked like a charm.
Originally Posted by Lord Helmet
I'm dreading the rears... I hate taking out the back seat since my sub box is attached to it. Is that silver paint? It almost look white in the pic.
yes it is Ultra silver paint...the lighting isnt real good. its in the garage.
yep i got quick epoxy too. and hope that will work.
actually there are two bolts to remove...and you just have to pull up the bottom seat to get to it. but when you remove that you have to pull the panel out towards you and look behind there to see an L bracket with a bolt on it....just squeeze youre arm in there to get that and pull and wiggle the bitch off. I just took them out because i wasnt sure if there were any bolts back there.
Maybe I'll tackle the rears this weekend if you say I don't have to pull out the whole back seat. I may hit you up fr some pointers later.
hey i finally finish the panels and put them back in....took the pics at night so the colors arent exact.
also got a new sticker a few days ago oh yeah. I let it be known....
@ the sticker!
It looks really nice man! Good job!
@ JDM!
Sorry, I couldn't help myself!
Ok, Stealth... I'm about to pull off those rear panels.
I really hope I don't have to take out that seat back. My sub box comes out with it.
Originally Posted by GreenMonster
Where can I get a sticker like that ??
<--- off to seach on ebay
<---still cant double quote
you dont have to pull them out, just the bottom coushins, i didnt see the screw that is covered up in the handle part. its just that one screw and the one underneath.
I took the seatback off it's hooks but I never pulled it out of the car, I just kind of worked around it.
honda_motor_co_4life
14
04-04-2007 03:17 PM
osyrhiz
1G CL Problems & Fixes
03-13-2007 01:15 PM
