Side Mirror Problems.....................
Old Aug 24, 2001 | 11:23 PM
dfv3.2CL-S's Avatar
Since i had my subwoofer and amp installed in my car I began to experience side mirror problems.
when I try to move the driver mirror inwards, it now moves outwards and down and if I try to move it downwards it move upwards and out and the same thing happens with the passenger side mirror.
Can this problem be due to the install of the sub and amp?
when you install the amp and sub is there any need to dismantel the doors(from what i know the door panel was not taken off) or Do they need to tap into the the fuse box?
Could the disconnection of the baterry wire at the terminal cause this problem and malfunction?
Please I need help with this issue.
Old Aug 27, 2001 | 03:45 AM
dfv3.2CL-S's Avatar
No body knows anything now. Please hlep
Old Aug 27, 2001 | 05:54 AM
ramiel408's Avatar
My best guess would be the unplugged wires and plugged them back in wrong. There are only two screws in the mirror that rotate... if it rotates one way the screw goes in and pulls the mirror in and rotates other way and the screw goes out and pushes mirror out... these two scrows that rotate basically control the movement to your mirror.
Then there is one more signal for the mirror heating... so they probably just mixed you up.
rockyboy
Aug 4, 2024 10:35 AM
Type S Zero
Feb 17, 2016 02:37 PM
guitarplayer16
Nov 29, 2015 02:03 PM
sockr1
Oct 1, 2015 01:31 AM
