Should I replace this K&N
Old May 20, 2009 | 02:21 PM
lothian110's Avatar
I cleaned my air filter today at its kind of beat up.
It is also still black after using the K&N cleaning kit.
I reoiled already in the pics below. The piece that is banged up is closed by the filter cotton smushed together, so i don't think anything is going in it.
When i changed my bypass valve for the intake, the pipe inlet was nice and clean so i think its doing its job.
Should I just replace it? What do you think? $38 shipped on amazon.
Old May 20, 2009 | 03:45 PM
TheWeez's Avatar
I Wanna Beer
Don't think it's a big issue. It should look like that when cleaned. It's fine.
Old May 20, 2009 | 03:59 PM
Dan's Avatar
Dan
Confused
What did you beat on it with?
Old May 20, 2009 | 05:17 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
It still looks good, I just cleaned mine for the first time in 140k miles and it was dirty as hell.
I first let it soak in soapy water for like 1 hour then i sprayed the K@N cleaner on it let it sit for a few minutes and then pressure washed it from the inside and outside. then i sprayed it with the oil (the oil was red) and now it works like brand new.
My K@N filter is alot bigger then yours!
this is B4 i started washing it!
Old May 20, 2009 | 06:55 PM
lothian110's Avatar
if my filter were that long it would almost be dragging on the floor!
btw K&N recommends not using high pressure.
just spray with K&N cleaner, let sit for 10 mins, rinse from inside out with low pressure, let dry, and re-oil.
AND try cleaning it every 30k miles! although i am sure its fine even after over 100k....
i don't know what happened to the filter, i bought my car with 30k miles on it and it was like that when i cleaned it the first time.
now i have 60k, so this is only my second time cleaning it.
Old May 20, 2009 | 07:04 PM
HI OFECR's Avatar
K&N has a warranty if you registered it or still have the prof of purchase.
MILLION MILE LIMITED WARRANTY
K&N O/E Replacement Air Filters and Air Intake Systems purchased from Authorized Dealers are backed by a Million Mile Limited Warranty when used primarily on paved roads and on vehicles for which they were designed. If one of these products ever fails to provide complete satisfaction, K&N will replace it.
Old May 20, 2009 | 07:11 PM
lothian110's Avatar
it was on the car when i bought it used, no proof of purchase... hmmm.. doubt they would cover it but i guess its worth a shot.
Old May 20, 2009 | 10:10 PM
Dan's Avatar
Dan
Confused
They will not warranty a filter that has been abused like that one has, even with a receipt.
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
Billu99tl
Sep 13, 2015 11:30 AM
