Shocks....
Old May 19, 2002 | 09:45 PM
ACURACR's Avatar
Got Boost?
Shocks....
What are the best shocks for our CL-S with Comptech springs? I am looking to get them within the next couple weeks...and where is the best and cheapest place to buy them. All help would be greatly appreciated....thanks in advance....
-Shane
Old May 19, 2002 | 10:44 PM
Red Rider's Avatar
Subie Dubie
Well you can tell from my sig what i'm gonna say, Koni yellows. I think they perfectly compliment the Comptech springs. Huge improvement in my handling.
Old May 20, 2002 | 02:17 AM
AztecRol's Avatar
The Screeching Toyo's
I too have the Koni Yellows!!! I them!!!
Old May 20, 2002 | 02:28 AM
mlrspwr's Avatar
excuse my ignorance
What is so great about Koni Yellows? I hear they are adjustable. Okay, that is good I'm sure. I'm getting HR springs soon and want to just stay with stock shocks. But then again maybe I can be convinced of the Konis worth by someone. I'm sure the ride will be even stiffer with the new springs. Think that spells any trouble with the stock shocks? Thanx for feedback.
Old May 20, 2002 | 02:47 AM
AztecRol's Avatar
Re: excuse my ignorance
Once you see the size difference between stock and the Koni's, you will start to understand!!!! The Koni's are almost twice the size in diameter!!!! They not only are adjustable, but they can handle the extra force exerted by the lowering of the car. The stocks will be able to take it for a while, but if left on, they will blow out!!!! The stock shock are made for comfort, so they are very soft!!! The Koni's are made for handling, so they are stiffer and can be adjusted even more!!!! WELL WORTH THE MONEY!!!!!! I would personally NEVER lower a car without changing the shocks as well!!!
Old May 20, 2002 | 08:29 AM
NOLACLS's Avatar
OK so how lone do they last....the stock shocks I would guess would blow around 50K right?? What about the Yellows??
Old May 20, 2002 | 09:37 AM
JSuppi's Avatar
Lifetime...!! :)
I too have the Koni yellows, and they are nice
As for life expectancy, I would expect the stocks (which is true in my case) to go out anywhere from 45k to 50k. Mind you they won't blow, but they will degrade significantly in performance to basically the point that they might as well have blown.
Koni's once installed should last the lifetime of the vehicle, one interesting point to note is that the Koni's where made adjustable (this was from reading off the Koni literature that came with the shocks) so that you can initially set it at the softest setting, and gradually over time you can readjust and tighten the settings to keep the same ride quality for ever ).
Old May 20, 2002 | 09:53 AM
NOLACLS's Avatar
Great info now what do they cost for thae set...like 600?
Old May 20, 2002 | 09:57 AM
JSuppi's Avatar
I think for the set (all 4) Tim (acp.com) had them for like +/- 500$, best price I have seen.
Old May 20, 2002 | 10:21 AM
Jeremyp80's Avatar
Cost question
where did everyone get their koni yellow shocks and comptech springs? and how much did you spend? Thanks!!!
Old May 20, 2002 | 10:28 AM
rondog's Avatar
Former Sponsor
handling is great, but what if your looking for ride smoothness and comfort? I already blew out one stock strut, maybe because of the mechanic's fault, but I still am looking for that stock ride quality with comptech spring look. (maybe even softer than stock)
Old May 21, 2002 | 05:22 AM
mlrspwr's Avatar
install for spring & shocks
Koni Yellows sound like a sound investment, especially with the springs. I mean, you will have to replace the shocks sometime anyway, so might as well get the ones with a lifetime warranty.
Quick Q: Should the price to install just springs EQUAL the price to install the springs & koni shocks?
I know they are pretty much part of the same assembly, but before I call the install shop and they try to dick me around, I might as well make sure via shared wisdom. Thanx!
Old May 21, 2002 | 09:10 AM
AztecRol's Avatar
Re: install for spring & shocks
The cost for installation should be EXACTLY the same. When they change the shocks or the springs, BOTH have to come out!!!! It is cheaper to do boht at the same time!!!!
TLsMD
Sep 7, 2010 02:24 PM
abptltypes02
Jul 27, 2009 08:49 PM
peternguyen504
27
May 22, 2008 11:23 PM
kramb
1G CL Tires, Wheels, & Suspension
Apr 5, 2007 01:35 PM
