Seat Belt Oddity
Old Fella
Seat Belt Oddity
Need some tech help here please. When I turn off the ignition, I occassionally can feel a slight release in my seat belt. It is very slight but noticeable nonetheless.
Anyone notice this? What is it? I wouldn't have thought that the seat belts were connected electronically to anything except the female part when the belt is inserted to tell when the belt is connected or not.
Anyone enlighten me on this?
Pete
Pete
umm just your fabulously imaginative imagination ). Seatbelts have pre-tensioners (slack takeup devices) that release... as well, if you lean back to let the seat belt retract after lock up, it will unlock itself inthe way you stated.
Re: Seat Belt Oddity
Pete
Pete
Just a guess.. Seat belt tensioner has battery power, when you turn off the ignition the voltage drops a little bit, thus tension drops a little bit??
Old Fella
Hmmm, Mercury. Seat Belt Heater, eh? Okey Dokey... I think I'll go with the tensioner answer..... Although I would have thought that it was a spring device and not electronic.... Again, just a neophyte trying to figure things out. And this one, I believe, is not in the manual!
Old Fella
Seat Belts
Jens.. No real worry. just curiosity. The feel in the seat belt is noticeable when you turn off the ignition. I'm OK with that, just curious what's going on! Or off as the case may be!
Have a great day!
Have a great day!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
