Scalbert
just disconnect the negative from the battery for about 15 mins.
connect it back start the car and wait about 5 mins before driving. then drive it like u stole it
sidemarker
sidemarker
sidemarker
sidemarker
Re: Scalbert
Originally posted by juice
I remember you talking about reseting the ECU by pulling fuse #13. Where is this fuse located?
Thanks,
juice
Thanks,
juice
you guys are silly, but if you want to reset the ecu, pull the battery terminals off and hold the + & - together for 30 seconds or so. your cpu is reset.
but your dreaming if you think it makes a difference. OBD2 vehicles don't work that way, sorry.
Originally posted by allmotor_2000
You should probably not say 'hold the + & - together'; someone might get somehow short the two!
um, guys, those are the instructions the acura tech gave me when i asked about resetting the ecu. use your head a little bit.
of course you must disconnect the terminals before touching them together the only way to cause a short would be to arc the two w/ a wrench or something.
Dude.... I know what you mean, but there might be a couple of individuals that don't. We arn't slamming you... just making sure the kids don't try something dumb!
It's good to learn how many Joules of energy a battery can hold....
Open the passengers side door and look at the side of the glove box with the door open. There is a cover for a fuse panel with a drawing on it referencing the fuses.
It is the 15 amp fuse, second from the bottom on the top row.
Nashua_Night_Hawk
11-30-2002 05:00 PM
Mint Julip
2G CL Frequently Asked Questions
07-17-2002 07:47 AM
