SC430 Camber Issues
SC430 Camber Issues
I know this is not the appropriate forum but having seen the issues my father-in-law has experienced I have to vent.
My wife's father owns an '02 SC430 paid for in cash. It now has about 36k miles on it and has been through three sets of tires; all with inner tires wear.
I have to digress for a moment. Before I met my wife (although I was a teenager) I had an interest in cars but never did anything with them. I understood the mechanics and controls but never touched them. My father-in-law started me off. He is an old school wrencher than knows the tricks to make things work, although the current computer stuff is a little out of his league, basic mechanical functions are not. Having been part owner in a speed shop during the hey days of the muscle car era he is certainly not a novice.
Now back to the original topic. His SC430 has worn out multiple sets of tires, one set replaced by Lexus. After the first replacement he watched the pattern and noticed inner wear. This indicated negative camber. So he pulled out yard stick and a straight line and measured almost 3 degrees negative camber.
Obviously it was taken in for an alignment. To keep the story short; the specs for the Lexus SC430 cannot be met. You cannot even achieve 0 camber. The best you can hope for is about 1 degree negative camber even though the specs state that it has an adjustment range of + camber range. However, there is not enough ability there to reach even the minimal mark.
This has been verified on multiple vehicle, not just his. None can even reach the factory defined specs.
I can understand some negative camber, but to be locked in this in a grand touring vehicle which cannot even be set at the factory limits is terrible.
I remember reading something similar with new Mustang Cobra. An owner had and issue and worked with the dealer. They couldn't figure it out. Called the factory engineers and they couldn't work it out. It ended up being a design flaw.
One of the members who is no longer active on this board had a similar issue with the alignment on his car. End result, lemon law'd it cause they couldn't figure out what it was.
Probably doesn't help but just sharing what i know Good Luck.
Re: SC430 Camber Issues
1) Federalization, AKA weight increase over Japan-spec.
2) Bushing re-spec for a more supple ride.
3) Truly hard driving.
The first is self-explanatory. The second is probably due to some marketer's demand that the car be both shod with run-flats and still ride like a Lexus. The third is simply more-than-usual spring settling, which has occured to the last two cars I have owned.
A solution if your father is mod-friendly is to look for adjustable upper arms. I believe between the IS and the GS (Aristo), the SC430 is derived from the latter platform and so there might be aftermarket arms from Cusco for the Aristo (being that it weighs less and is available with the Supra Turbo engine, so hence considered a credible sporting platform there) that may fit the current Soarer (SC).
Alternatively, you could always pursue custom-fabricated springs. But he'll have to be okay with a higher ride height.
thats weird, post this at www.clublexus.com
Re: Re: SC430 Camber Issues
Originally posted by DtEW
This happens through three reasons:
It has been realigned numerous times and every time the vehicle cannot meet spec. As mentioned, this is not exclusive to his, one dealer tried to get within spec with two cars on the lot and failed. The negative camber was easily visible from behind the vehicle and was in the front and rear. It appears that manufacturing and design have somehow gotten out of alignment.
He does have his own solution but hasn't shared with Lexus. A grinder can do wonders at times...
But I agree, it most likely is some issue related to your number 1 or 2 points.
multiple people at the 350z forum describe this exact problem. seems there is no way to adjust the front camber on the Z.
http://www.my350z.com/forum/showthre...threadid=23350
mine only has 1200 miles on it..i'm a little nervous.
Originally posted by darrinb
scalbert, r u talkin about that red sc u smoked at the track?? i lost those vidz, do u still got em??
SC430 vs CL-S6
At that time headers and a custom intake. It should be noted that it was a nasty day also. Dew point was near the ambient temps (this was central Georgia) and I had a DTC set (P0300 Random Misfires).
IMO, 14.1's could have been had if the car would have agreed and the humidity would have been below 70% (which is good for this part of the country).
nuldabz
09-03-2015 05:49 PM
