SC Revs
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Is it normal for the revs to go up instead of dropping when you shift into gear. I figured its the parasitic effect of the charger not letting the revs drop in between shifts. Wondering if this is normal.....
6mt swapped..smart
happens in my car too and i'm not even s/c. If I let off the gas and press in the clutch the revs will go up maybe 100rpm quick and then drop, almost like short lag in the time the engine take to revs down from the time you take your foot off the pedal. I also checked my throttle cable to make sure it wasn't sticking which is wasnt. I don't have my clutch position switch hooked up though because my car is swapped, does anyone know what that sensor's function is?
Whats up with RDX owners?
......is normal. Its the dual mass flywheel at work.
And it did this even before I installed the SC.
cycdaniel
12-17-2019 10:58 AM
DerrickW
11-15-2015 05:52 PM
