Sc Oweners Help !!!
Old May 8, 2005 | 12:32 PM
Hurleysurf24's Avatar
Sc Oweners Help !!!
OK i got the sc base in and i set it into the bracket ... i trimmed the fan housing and then placed it in.
Anyways i not iced that the freaking fins on the fan are hitting the base of the sc !!! WTF MAN ?
Would it be that big of a problem to trim about 5cm off of the corner of each blade so that it clears correctly? Or will this cause some sort of problem ?
__________________
Old May 8, 2005 | 12:49 PM
Seattle Cl-S's Avatar
Blown LS6!!
I wouldn't think it would hurt anything...but I'm definitely not an expert on these things.
Old May 8, 2005 | 01:10 PM
ThinJim's Avatar
Hey barf_n_surf... trimming the fan blades may throw off the balance of the fan, you might be able to get it close though. Other thought is.... have you mounted the blower belt and tightened it? if you haven't put the belt on yet, the blower may be laying lower than it would with the belt on. put belt on and then check. there's not much room when all is done, maybe a 1/8 - 3/16 of an inch clearance. good luck
Old May 8, 2005 | 01:11 PM
yea i eprsonally dont see how it really could do any damage .. those fans dont spin fast/efficiently enough to be knocked out of balance if it spins, in my opinion. So i dont see the problem in trimming about 3-4 cm off of each fans blade.
But yea i just wanted to check with all you guys first
Old May 8, 2005 | 02:58 PM
NSXNEXT's Avatar
Might wanna figure out why it doesn't fit. I've never heard of anyone having to do this.
Old May 8, 2005 | 03:02 PM
hey i havent gotten the belt on yet ... ill let you guys know later today ... im going to readjust all the brackets, and play around a little with how everything sits.. but i dont think i can fenagle anotehr 3/8" out of it ... hopefully we will see
Old May 8, 2005 | 03:03 PM
Smitty's Avatar
you can trim the fan SHROUD.... I HIGHLY doubt the blades of the fan are hitting the jack shaft.
go to Comptech's Website and download the directions... it tells the TL guys what they need to do... no trimming is needed on the CL-S shroud.
Old May 8, 2005 | 03:14 PM
hey i did ... its actually hitting the blade ... by about 5-8mm.
its not the shaft ... its the actual base of the sc that is hitting the fan
Old May 8, 2005 | 05:43 PM
Smitty's Avatar
.. no way should the fan BLADE hit the Blower unit.. put the charger in correctly or take it to a tech... you clearly have NO clue what you are doing.
trimming the fan blades...
Old May 8, 2005 | 05:52 PM
Smitty's Avatar
reads like your blower brace is installed incorrectly.
go to Comptech Site and download the directions... then print them out... then try reading them and seeing where you went wrong.
Old May 8, 2005 | 06:21 PM
allmotor_2000's Avatar
Boy you are tough!
Are all three S/C mount-point bolted on? If that is the case, it cannot hit the
fan blades IF you have the factory radiator/fan assy. There is a possibility that
the fan assy is not OEM - what year is your car? Most likely something is not bolted up correctly.
Also... you could notch the fan blades, but try to do so evenly.
Old May 8, 2005 | 06:30 PM
bigguyonbike's Avatar
13.2 @ 104.76mph
you need a spacer for the fan blade. call comptech, they should have the part in stock for you.
Old May 8, 2005 | 06:31 PM
13.2 @ 104.76mph
the part number is 355-137 (fan motor spacers) there should be 3 of them.
Old May 8, 2005 | 06:39 PM
13.2 @ 104.76mph
it doesn't fit because the he has a 6sp sc kit and is trying to put it into an auto.
Old May 8, 2005 | 06:44 PM
13.2 @ 104.76mph
step #4
http://www.comptechusa.com/instructions/ins125.pdf
Old May 8, 2005 | 06:57 PM
Smitty's Avatar
a Auto TL... The S/C kit for the TL's comes with the new fan shroud that is already trimmed... the kit also comes with a return label so you can send the TL shroud back after you exchange it with the trimmed one..
mrsteve's Avatar
No it is an auto kit, came off my car without problems. I just don't think he's capable of doing the install himself.
After all he installed the alternator and SC without connecting the belt from the crank pulley to the alternator.
Old May 8, 2005 | 06:58 PM
mrsteve's Avatar
Oh... maybe he gapped his injectors wrong... that could do it.
Old May 8, 2005 | 07:00 PM
Smitty's Avatar
Originally Posted by allmotor_2000
Boy you are tough!
I know... but there is no way he should have to trim the blades of the fan.. he has a mount screwed up somewhere.
Old May 8, 2005 | 08:17 PM
13.2 @ 104.76mph
he must of mounted the fan motor on the wrong side of the shroud.
Old May 9, 2005 | 12:48 AM
why the fuck are you guys picking on me, i came here asking for help and insight, i expected more from you then to chew my ass out
the sc is installed and the brackets are all mounted correctly ...
and i left the belt til last steve. everything is up and running and i will have to look into the fan issue more tomorrow. Everything but the esm is done.
Old May 9, 2005 | 01:00 AM
Allout's Avatar
Blown is Best
Bigguyonbike is putting you on the right track. Did you or did you not have the fan spacers in your kit? It's not purely trimming the fan shroud on an Auto.
Old May 9, 2005 | 01:10 AM
i may have missed it ? ill go check that tomorrow.
STEVE .. THE NEW FAN SHROUD NEVER CAME WITH THE KIT
maybe this is a reason ?
Old May 9, 2005 | 02:39 AM
figured out what it was ...
steve, the parts that you shipped to me never included the new fan shroud. im pretty sure this is why the fins are hitting the bast of the sc.
Old May 9, 2005 | 06:50 AM
mrsteve's Avatar
My shroud was trimmed, never had a new shroud.
Old May 9, 2005 | 07:23 AM
Smitty's Avatar
we are helping you...so stop your fucking crying.
The TL Supercharger KIT comes with a new fan shroud..... YOU bought a USED CL-S kit... the CL-S kit DOES NOT come with a new fan shroud because it does not need it.
Old May 9, 2005 | 07:25 AM
mrsteve's Avatar
Old May 9, 2005 | 08:13 AM
Smitty's Avatar
Steve that kit came off a TL right?.... you never took the shroud because you never needed it.. correct?.... and the TL guy who sold you the kit sold his car..right?
Old May 9, 2005 | 09:35 AM
mrsteve's Avatar
Nope... it came off an '03 automatic CL-S
Old May 9, 2005 | 11:34 AM
OK so we solved the problem I need to buy a new fan shroud
Old May 9, 2005 | 09:18 PM
SC Problem Part 2 ....
OK fixed the fan problem ... got it to fit properly.
So we get everything on properly .. i think
We try cranking it over and put put put put the car is struggling to turn over.
We jump the battery and put put put put ... nothing
We tried it again and it went put put put ... cranked over but then started to sputter heavily .. I guess fuel was pooled in the motor?
So we tried a few more times and nothing
Then we crank it again and put put put put put put put ... nothing - and my friends tell me they smell coolant.
I let them crank it one more time put put put put put put put ... nothing - and I agree with them its coolant.
So what symptoms would you guys conclude? I think that i just have one of the vacuum lines switched with one of the coolant lines ... do you guys think this is the soruce of the problem ?
Old May 9, 2005 | 09:29 PM
Smitty's Avatar
So we get everything on properly .. i think.
And are you going to tell us what you did to correct the problem?
you better pray to the dear lord that you do not have a coolant line in place of a vacuum line.... if you do, you might as well go submerge your air filter in a bucket of water and start the car...
you are prolly injesting coolant and you will ruin your motor...
Old May 9, 2005 | 09:32 PM
nice ... well im going ot have a wonderful day tomorrow
i just recessed the motor
Old May 9, 2005 | 09:34 PM
and i ordered a new fan shroud from comptech so that should be here in a day or two
Old May 9, 2005 | 09:44 PM
mclarenf3387's Avatar
Time for a new motor
Old May 9, 2005 | 09:49 PM
i guess so guess im not buying another car
Old May 9, 2005 | 09:50 PM
btw i checked the coolant levels ... and they were all topped off ?
Old May 9, 2005 | 09:52 PM
cdrink80's Avatar
I Want a GPW 03 S2k
J32A
Pull the plugs and make sure there isn't any coolant in the engine.
Old May 9, 2005 | 09:54 PM
ill check that tomorrow .. i dont think there is .... but yea
if there is coolant in there .. which im doubting what gets done ? cant it just get sucked out or is that it .. its over
