RPM wont pass 5800 =/
Old 11-06-2010, 06:58 PM
  #41
sanya916's Avatar
you probaly need the ecu from the 03 cls...
Old 11-09-2010, 12:10 AM
  #42
Ultra Negro
OperationDarkie's Avatar
Just try plugging in an 03 cl s ecu.
Old 11-22-2010, 11:39 PM
  #43
black_type-s's Avatar
i have an 03 cl-s ecu but they want 125 to program key so im goin to a mechanic he gonna check oil pressure and vtec switch, if everything seems fine, will program key for 03 cl-s ecu!
Old 11-23-2010, 05:39 PM
  #44
typeR's Avatar
i assure u the fuel cut would come at 4800 on the vtec change over if it were vtec or oil ....ill link a vid of my doing a smokey street run .... if u listen close u will hear the baby fuel cut at 4800 in first....
http://www.streetfire.net/video/sorr...een_173657.htm
Old 11-23-2010, 06:35 PM
  #45
lowrd on tein CS biatch
CL-S progression 01's Avatar
2 months and no fix??
have you lost your mind yet driving that thing?
i hope u got a next set of wheels or i'd be tearing my hair out.
Old 01-14-2011, 05:32 PM
  #46
Just an update... Its not the ecu!! Guessin its the oil pump!!
Old 01-14-2011, 05:50 PM
  #47
typeR's Avatar
u would not get fuel cut at 5800 as u say ...but really 5500 which is the limp mode park/neutral fuel cut parameter ... it would happen at 4800 when the car would try to change to the high lift high duratation part of the cam
Old 01-14-2011, 07:11 PM
  #48
Regional Coordinator (Texas)
nspec_ya4's Avatar
so ur saying u still havent tested the vtec solenoid?
Old 01-14-2011, 10:57 PM
  #49
Ultra Negro
I still think it is the ECU, because last I checked you can still rev an engine if your oil pump goes out, it just won't last very long.
Old 01-15-2011, 03:06 AM
  #50
but i've gotten the REAL limp mode and car is tooootally different in limp mode, im talking bout 3000 cut off!!
Old 01-15-2011, 03:08 AM
  #51
one of the first things i replaced!! i even checked to see if ecu sent the signal switch and that was fine too!
Old 01-15-2011, 03:12 AM
  #52
but i just replaced the ecu today for a 2003 cl... still nothing!
i've read somewhere where oil pressure not enough for vtec but not bad enough to send CEL
it's my last resort, ive tried everything!
solenoid
ecu
manifold
Old 01-15-2011, 06:37 AM
  #53
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,323 Likes on 4,900 Posts
Have you checked your fuel pressure?
Old 01-15-2011, 07:18 AM
  #54
typeR's Avatar
anything oil/vtec is gonna show at exactly 4800keep trying random crap and spend more time and money or find out what it really is and fix it .... can u get me a good vid of sound of engine while displaying its symptoms ? also do u have asccess to a code reader just because theres no CEL doesnt means theres no info there ... the service dept has a device called consult or something to that affect they can see everything going on with that tool
Old 01-17-2011, 07:42 PM
  #55
http://www.youtube.com/watch?v=YbCg8bPXnS0
Old 01-17-2011, 08:07 PM
  #56
civicdrivr's Avatar
No CELs? I see that your dash is lit up like a christmas tree but I cant see the CEL.
Old 01-17-2011, 08:33 PM
  #57
03 acura cl type s
rush's Avatar
CLaer that CEL first then look on top of your Oil filter theres a plug thats not pluged in unplug it & plug it back in its your oil presure switch its definatley not all the way in .its green .
Old 01-17-2011, 09:42 PM
  #58
typeR's Avatar
its ECU related thats all i got ... get them to ook up the consult...if it were key car wouldnt start .... thats the imobilizer system
Old 01-27-2011, 06:56 PM
  #59
i changed ecu into 03...
i change solenoid...
CEL is ONLY emissions (straight pipe)
i unplugged and replugged 'green' oil pressure switch...
its a J32A2 so its for sure a type-s...
like i said, car drives purrrrrfect except for the 5800 part but i dont even race like that, im jus puzzled!
Old 01-27-2011, 10:45 PM
  #60
nspec_ya4's Avatar
the reason why i was asking you to check the solenoid was to first see if it works. if it did work, then check to see if its getting power when its suppose to. the way you can do that is by tapping a wire into it and run it to a light on your dash so as soon as the ecu gives it signal, that light will turn on too. There could possibly a problem somewhere between the solenoid and the ecu.
Old 01-29-2011, 08:40 AM
  #61
03 acura cl type s
rush's Avatar
what code are you getiing and if want that emisions light gone get the o2 spacer try vibrant or google .but i need to know all the codes your getting
Old 02-08-2011, 01:14 PM
  #62
Answered!!!
Bad connection at the switch, mechanic just cleaned connectors and that was it!
nspec_ya4... Good shit, you did mention a connection problem!!!
I just want to thank everyone for trying their best and taking their time into helping me out!!!
Old 02-08-2011, 05:12 PM
  #63
ParaSurfer1979's Avatar
Answered!!!
Awesome. Thats exactly why forums like this are here.
Old 02-08-2011, 06:47 PM
  #64
nspec_ya4's Avatar
cool deal.
DerrickW
11-15-2015 05:52 PM
Houston
10-08-2015 01:27 AM
wubly
4G TL Problems & Fixes
10-06-2015 02:45 PM
xsilverhawkx
10-05-2015 11:00 AM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: RPM wont pass 5800 =/
